This might be a NOOB question but, if I wanted to do some testing, could I use a blanket to fill the gaps when firing forward from trunk. It is only going to be for testing firing forward, I am not totally commited to the idea just yet, but would like to get it as close to sealed off as possible without making it permanent....or a big mess. LOL
Does the tape thing actually work because I have seen people do it that way as well?
Any ideas would be helpful, if it works out I will be doing a build log for the box as well as completely sealing it off.
If I can get it totally sealed off, will I still need to use sound damping in the trunk or just focus on the inside panels?
Sound deadener in the trunk. No not if you sealed off. Gorrilla tape might do the trick. When your committed get the sray foam/insulator stuff it works great
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
It has potential to be louder if you sealed it off correctly . I did it with gorilla tape , and for ke facing port and sub was louder . For me ...
Cuss I didn't seal it off right .... And even then I almost stop rattles in the trunk 90% it felt amazing cuss I hate it !!!! So yea u will focus all of it the cabin , if done correctly
its ugly but air tight
R.I.P!
(Nov-29-2009)
92 explorer
current build
Is their anything Duct Tape can't do? LOL
Thanks for the info guys. I'll start on it in a little while, pictures and all just to see if it changes anything for my car.
You don't see a lot of 91 Accords with big systems, hopefully I will be the first and loudest.
Going to take a while though. :shrug:
Damn, how many rolls did you use? LOL. It is a good thing my seats can fold down.....and up to hide the mess I am about to make in my car :drink40:
the bottom didnt need to get done but i figured hell why not make it all look like its been taped to make it look loud and surprisingly i only used 3/4" of a big roll
another alternative would be to (and i've been wanting to try this for a while) get a bunch of plastic bags and layer them inside eachother and then fill the bag with expanding foam so the bag becomes the shape you need and you will be able to take it out later if needed
now im not sure if the bags will hold up but its been an idea in my head for a while i been wanting to test
R.I.P!
(Nov-29-2009)
92 explorer
current build
OK, I just might try the plastic bag idea. I will let you know if it works or not. After checking it out in my trunk, their is not a lot I have to do to seal it off, I think. I'll give both ways a try and post my ugly pics later.
Oh, I still have my 6.5's in the stock location, what do you think I should do with those?
I saw you had you rears in boxes, thats why I asked.
Edited by samslowp1s
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
