Relyks Posted May 8, 2011 Report Posted May 8, 2011 i was looking at the manual of the amp and it shows a pics that has 1 sub and shows a wiring like diagram where you take both positive on the amps and put it on both positives of the sub and both negatives of amp on both negatives on the sub then says 4ohm - 1ohm what does that mean cause far as im aware there is no way to wire a 4 ohm dvc sub at 1 ohm. Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Supercharged DCs Posted May 8, 2011 Report Posted May 8, 2011 I'm guessing it has a ++-- speaker input, right? Wire the positive speaker wire to the first + and the negative speaker wire to the first - Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
Relyks Posted May 8, 2011 Author Report Posted May 8, 2011 ... ill take a picture of it and show you what the manual says i know how to wire it lol im just saying ++-- there first 2 positives to the 2 positives on the 4ohm dvc sub and the 2 negatives on the 2 negatives of the 4 ohm dvc sub is what the manual says to get a 4ohm at 1 ohm load is all im saying im wiring it 2 ohm at this very second. Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
Supercharged DCs Posted May 8, 2011 Report Posted May 8, 2011 Alright, but the way you explain it seems to be the exact way my DC2k manual looks. It says 4-1ohm load, and shows one Sub with the positive going to both + and the negative going to both - If Im right about that, then The 4-1ohm means 4 through 1ohm, not 4 or 1ohm. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
kirill007 Posted May 8, 2011 Report Posted May 8, 2011 Alright, but the way you explain it seems to be the exact way my DC2k manual looks. It says 4-1ohm load, and shows one Sub with the positive going to both + and the negative going to both - If Im right about that, then The 4-1ohm means 4 through 1ohm, not 4 or 1ohm. No, it means you can wire it to 4 or 1 ohm. With 1 dual 2 ohm sub. Quote Thinking is the root of all problems... You ALWAYS get what you pay for.
Supercharged DCs Posted May 8, 2011 Report Posted May 8, 2011 Really? How would you get a 2ohm load on the amp then? Wire to the first + and the second -? Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
canderton01 Posted May 8, 2011 Report Posted May 8, 2011 (edited) Really? How would you get a 2ohm load on the amp then? Wire to the first + and the second -? You can't get a final load of 2 ohm with a d2 sub. You can only wire to 1 or 4 ohm. You'd need a d1 or d4 sub to wire to 2 ohm. Edited May 8, 2011 by canderton01 Quote 2002 Camry XLE 35% tints all around 17'' Enkei FD-05 rims Fi Q15 in 3.8cu ft box tuned to 32Hz Pioneer DEH-P7200HD AudioQue AQ1200d 4 Gauge Tsunami wiring/RCA's mids/highs - OEM JBL system AudioTechnix Deadner Big 3 upgrade My YouTube
Supercharged DCs Posted May 8, 2011 Report Posted May 8, 2011 I know that, but the OP is running a D4ohm subwoofer, which can get a 2ohm load. Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
speedball1978 Posted May 8, 2011 Report Posted May 8, 2011 if you want a 1 ohm final load go buy yourself another 4 ohm dvc sub and your problem will be solved.. a single 4 ohm dvc sub can only be wired at 2 ohm or 8 ohm nothing more nothing less Quote
Relyks Posted May 8, 2011 Author Report Posted May 8, 2011 i dont got a problem lol mine is wired at 2ohms and is a d4 aq sub in 2.00 cu.ft at 35hz so mine is fine. Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12
