15" Sundown Audio sa15d2 TESTED!!!
love the video's of the subs being put through the paces keep em coming :popcorn:
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
0 gauge direct leads FTW haha
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Good testing Ric ! For reference that is also my sub - I'm not sure if I mentioned in the letter or not. Pulled it right out of my Jeep :drink40:
* Testing @ my shop
* Dash test @ nSPL Show
* Outlaw test @ nSPL Show
I believe I had around 15-20 burps total on it with ~7kw clamped before I sent it over your way -- but I do burp straight up rather than a long roll so a bit less thermal stress. I also used that one to test specs for our PDF spec sheet that I sent with the driver.
If you'd like we can try the aluminum coil in there -- which we offer on re-cones for SPL guys. I'd expect a fair amount better performance at 61 Hz out of the lighter aluminum coil.
The SPL recones, are they only for a high tuned box, I ask because I have the 2 sa-12's and would like the SPL recone kits but my box is tuned to 33hz and a does a 141.7 at 33hz in the trunk not sealed off, I may tune higher later like 38-43 but not for a while. Would the SPL recones still work for my setup as is??? I would be ordering them first week of Nov for a show later that month. Thanks
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
You will lose SPL @ 33 Hz with the SPL coil option.
I would like to keep sundown as my subs, can I pm ya?
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
Dam a few db down from the copper? Maybe extra added weight from the glues?.... Jk. But wow 156+ from a 600 watts is still pretty impressive. Great vids!
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
Yea I know :( I was hoping to see a better number. For some reason both of the spl recones were down from the standard copper. Strange as it may be... That's spl for u.
Still a good number either way. And if I only roll it once I'm sur it would do 155 consistently with no problems.
  • Who's Online   0 Members, 0 Anonymous, 1646 Guests (See full list)
