I'm waiting on my 10" alpine type r, so i figured i should go ahead and get the box done before it gets here. I drive a 2000 Toyota Solara, i'm going to be running about 500-550 rms to it. What would a good slot port enclosure size and tuning be if i'm trying to get real low (slam the decaf lows)?
Pioneer 6300ub
Rockford Prime 6.5's
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
1.4 Cubic Foot Enclosure Tuned to 34 hz
Stinger 4 Gauge Wires
Consider one of these
http://www.decware.com/newsite/dbk10.htm
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Or one of these scaled down for a 10"
http://www.decware.com/newsite/dbk12.htm
nice thing about this design is you can add a second sub(clamshell) later if you want. Same with the DBK10
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
no thanks, i just want specs so i can build my own
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
find the subs optimal ported box volume.(should be in your manual) then Use Torre's calculator to find the specs for the sides and etc. and you can tune your port as well.
1999 Dodge Caravan
[TrashMobile]
8ga Power/Ground
AudioPipe APSM-1300 (subs)
Scosche 550 (mids/highs)
Boss 735UA Headunit
(2)Hifonics HFi12D4
Still Under Major Construction..
well i was just trying to figure out what i should tune too, maybe by experience or suggestion
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
Tune to around 34hz, and if you want more help try to give max dimensions.
34 hz with the box built to factory specs?
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
That is specs. You buy the plans and build the box yourself.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 566 Guests (See full list)
