sexy looking subs for sure look like they can handle some power and 3 15s would get nasty loud in that little stang
i want those subs
R.I.P!
(Nov-29-2009)
92 explorer
current build
i want those subs
I would be pushing it fitting 3 15s since i only have 13cf or so to work with before port and subs displacement
also 8 10s is more cone area than 3 15s it is closer to 4 15s
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
well get your ass working and get er done
R.I.P!
(Nov-29-2009)
92 explorer
current build
Nice...
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
well i got tired of glassing so i called it quits on that and figured i would move on and do some bondo work. This is my first time using kitty hair and it sucks. I didnt think it would be that big of a b1tch to work with
Started working on a the first corner and made one hell of a mess.
Time to rebuild.
TEAM DTF
kitty hair is nasty to work with, the fibers drag clumps all over, and suck to smooth out. With all the resin and fiberglass, that should be plenty strong enough....why use the kitty hair?
And this is coming along nicely....trying to talk my wife out of her civic for a wall build.....lol
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
Tuned in man, gotta love small subs on a wall :D
just trying to get everything to be a little bit more stronger. but the main reason im doing it because im gonna try to get it all as smooth as possible and try to get the corners rounded a little better
Time to rebuild.
TEAM DTF
