Got Fi Q 15" Want somethung louder (DC?) but can't upgrade power, T1500.1
I trust you guys so I will do it, but obviously I suck at this. I can build it to be indestructible, but I guess I don`t know the theory behind it. I played some test tones and the high 40hz`s were the loudest. J-Lane, with yours tuned so low, where do you peak?
I haven't really played any test tones on it but I'll admit if I listen to most older (early '90's) Hip-Hop/rap I don't have much bass because my box is tuned so low. If I had the time to redo my box I would probably go with 30 Hz because I still like the lows but there are a few songs I like that just don't hit that low. Especially considering I don't like chopped and screwed stuff. I suggest using a slotted port just because you will be able to get the exact port area you require just by tweaking your measurements. Good luck and post some pics of the new box when its done. :good:
I`ve been holding off on posting a log until I was finished, mech alt, 3 batteries, 28 speakers and 17 tvs. In a Ford Focus. And now its going to take a little bit longer. But I`m glad I talked to you guys, Thank you.
Google it
1 alt and 3 batts for all that? Thats like powering a nuclear reactor with a wall socket, broski
The amount of speakers don't regulate current, LOL. Depending on the batteries and other amps, his electrical may be decent enough.
The other thing is, you do not have to tune low to play low. For your money, I would say hit up RAM designs and pay for a plan. Easy to follow, very frugal, and built to perform just nicely.
The subs pull the most current, so like 2500ish at 1 ohm, and there's a bunch of people on here with more running on stock alt and batt. I`m gonna build the biggest box I can. Then do the port. I"m sure someone on here will help me out with the port measurements.
Google it
^^^Second on RAM designs. He did my box and I have two level 4 12's each on a Punch P500-1bd and it slams! My box is 4.1^3 ft net and tuned to 30 hz. I can't hit anything above 120 hz very loudly, but that's what midbass and crossovers are for plus I listen to mostly rap and c&s music.
17 TV's though?
a TV isnt going to pull that much, and what if his three batteries were say...XS D3100s. either way, i think hes alright. i dont see his voltage being such a huge issue at the moment, but the enclosure is DEFINITELY a huge problem.
  • Who's Online   0 Members, 0 Anonymous, 581 Guests (See full list)
