209er Posted May 26, 2011 Report Posted May 26, 2011 Is my 1700 brutus good enough for a 12 BTL...Or should i stick with a BL... <p>Pioneer AVIC 6000 NEX, JBL 660c Components - FI SP415- Arc audio xdi2000.1- Xs Power- 0 gauge, Big 3 Upgrade Dc Power xp270
CaptainzPlanetz Posted May 26, 2011 Report Posted May 26, 2011 Is my 1700 brutus good enough for a 12 BTL...Or should i stick with a BL... You would probably be better of with the 4" coil BL, however if you built your box to the larger side of recommended specs you sould be fine, then later you could get a larger amp and keep the same sub. ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
Craig28 Posted May 26, 2011 Report Posted May 26, 2011 Is my 1700 brutus good enough for a 12 BTL...Or should i stick with a BL... You would probably be better of with the 4" coil BL, however if you built your box to the larger side of recommended specs you sould be fine, then later you could get a larger amp and keep the same sub. bls have 4 inch coils? TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
CaptainzPlanetz Posted May 26, 2011 Report Posted May 26, 2011 Is my 1700 brutus good enough for a 12 BTL...Or should i stick with a BL... You would probably be better of with the 4" coil BL, however if you built your box to the larger side of recommended specs you sould be fine, then later you could get a larger amp and keep the same sub. bls have 4 inch coils? The new onces yes there is an option for the 12's and above for a 4 inch coil ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
notorious97200 Posted May 26, 2011 Report Posted May 26, 2011 I love my 12" btl on my Sundown saz 1500 : sound really good . I never meterd anything but it's loud !!! I'll have an saz 3000 today, I hope everything will be alright ! BTW : my box is 2.1 ft3 at 32 Hz, sub up, slot port to the side of the cargo area.(look at my avatar) Get a btl, and upgrade your amp later if you need it ! black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
redbaron80 Posted May 26, 2011 Report Posted May 26, 2011 Get the btl. In my experience my RE MT was 1.2 DBS louder than my RE XXX on same power (1,500 watts) I later gained an additional 2 DBS with more power (3,500 watts each) Official Scores at the Dash. and YES. My Bass Boxing is louder than Burp! - 155.5 DB Drag Burp- 155.6 - IASCA Bass Boxing on music (30 seconds straight) sealed up Builds 1. The Acura Integra build = http://www.stevemead...s/page__st__6802. BLK SIN Build = http://www.stevemead...w-pics-10-6-07/
209er Posted May 27, 2011 Author Report Posted May 27, 2011 btl it is thanks <p>Pioneer AVIC 6000 NEX, JBL 660c Components - FI SP415- Arc audio xdi2000.1- Xs Power- 0 gauge, Big 3 Upgrade Dc Power xp270
