So, heres the deal, i took off one of my grandfather old hazy tailights, and decided to try wetsanding. i started out with 400grit, moved up to 600, then 1000, 1500, and finally 2000, i feel as tho i did a thorough job, yet they're still as hazy as ever, but the weird thing is when the water is sprayed on them, they look fantastic, the plastic looks new, but when dry, as hazy as ever. i hit it with plastix wax, and that didnt help. Anything i should know, or any tips you guys might have? anything is appreciated.
Edited by SkylarDunn
Getting bass into the cabin of a W124 mercedes is impossible.
Current setup:
Temp 1999 panasonic HU
rockford 300.2 for fronts
rockford 200.2 for rears
rockford 400.1 for sub
Leaning towards a 8" in an exponential horn
DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
The actual kits they sell at auto part stores work very well. My friend tried the samd thing you did. Threw some sandpaper on there and it made it worse. Now you can see swirls too.
Big 3 with Yellow Top
My guess would be there are micro level scratches that when sprayed with water fill with water giving a clear lens look. If you are going to end up with new tail lenses anyway maybe try a coat of clear on them and see what that does?
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
The sand scratches need to be polished off (With buffing compound). The lens looks dull, hazy, yet really smooth right?
Edited by solo_x18
Derp.
Mhm, extremely smooth, i guess i'll try adding a few coats of clear and wetsanding that. And i dont need a kit, i have boxes of the pads you use for wetsanding with a drill, the velcro came off of my 2k grit pad today tho, lol, and i only had one. i'll pick one up tommorow at orileys, since i know that method works like a madman, i just had the sandpaper around so i figured i'd try it.
Current setup:
IIRC you'd still have to do a type of finish buff/polish after the wetsand/clear.
Derp.
Yeah, you'd have to protect the clear of course. I would be using mothers plastic polish unless you can suggest something that would be better.
Current setup:
Thats where a protectant wax comes into play. lol
Pics of before and afters? Or just afters?
Derp.
i'll go take some right quick.
Current setup:
