There shouldn't be any difference on how any of the ports sound from one another but have never tried doing a comparison either, but you will gain space inside the enclosure using round or aeroports over the slot port.
EDIT: The gain will be from the efficiency of how well the round and aeroports are over the slot port.
Thank you for actually answering. So what you are saying is there is not difference in the two ports in themselves, but when put into use, the only possible gain is the fact that the aero will free up more space in the box. Makes sense I guess. I just feel like the little bit of space won't be noticeable to the ear...at least not enough to make up for the work of making an entire new box.
with aeros you also dont need the 12-16^3 of port needed for port area
you can get away with 9-13 if im not mistaken
been a while since i've used the aeros i got
R.I.P!
(Nov-29-2009)
92 explorer
current build
Well when your using 16" of port per cf. vs. 9" of port per cf. there can be a noticeable difference in volume inside the enclosure for you to use.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
^^^very true
