Mikesmith0890 Posted June 23, 2011 Author Report Posted June 23, 2011 nope, just made it a snug fit. and it worked great, no movement at all. Extremely tight fit between the two pieces to get it that way, but im not complaining. It worked out awesome. I'll have to look into it more. Needing a new one for mine. Looking at the 5901 viper or this. AlphaDamp Sound Deadening CDL Mat - The best Vibration Damper Ever! I'd hit that so fucking hard whoever pulled me out would be King of England. Lol... looks like we were on the same page. Car-B-Ques suck.ya, tires and paint burning make the marshmallows taste funny.
fyerbyrd22 Posted June 23, 2011 Report Posted June 23, 2011 for the price, its great...but its difficult to beat a viper...where u gonna put ur amps?? personal build in progress http://www.stevemeadedesigns.com/board/topic/188656-2013-kia-sorento-6-12-no-wall/ www.facebook.com/TurbulentDesigns
Mikesmith0890 Posted June 23, 2011 Author Report Posted June 23, 2011 The GP3D will prolly get a glassed amp rack on the front of the box facing the cabin, and the RF 4 channel is most likely going to end up in the trunk. AlphaDamp Sound Deadening CDL Mat - The best Vibration Damper Ever! I'd hit that so fucking hard whoever pulled me out would be King of England. Lol... looks like we were on the same page. Car-B-Ques suck.ya, tires and paint burning make the marshmallows taste funny.
727Designs Posted June 23, 2011 Report Posted June 23, 2011 Any HPP model crown vic or murcury with the I wanna say 8th didget of the vin has an XX it means the block is a windsor, most are romeos.... a windsor like mine is exactly the same but instead of the bottom end being safe to 400 to 500 hp the crank is fordged and the stock bottom end will handle much more than 600.... I've even heard 1200+ 1 to 10 runs on a strip before it pops but an impressive # for a stock bottom end..... All that being said I don't think ull see to much improvment going to PI heads because they are still 2 valve ud be better of with cobra 3v heads or maruarder 4v heads if they will fit...... or go grab a grand marquis motor So much misinformation here. There is NO difference in Windsor bottom ends and Romeo bottom ends. The only difference in them is the Windsor uses 13 bolt valve covers and does not have as much thread for the spark plugs, where as the Romeo has 11 holes and has more threads. The Windsor heads were notorious for blowing plugs out of the heads. The Windsors were more plentiful up north and in Canada where as the Romeo's were more common down here. If you research it almost everyone suggests going with the Romeo heads. Won't see much improvement with the PI heads only because there 2 valve? LOL, the PI heads are the single biggest improvement for the money you can do to those cars. The smaller combustion chamber makes for a nice bump in compression as well as the ports flow better than stock, match that with the PI cams (if you go aftermarket make sure to do research on piston to valve clearance!!!), and the PI intake with the longer runners and you're bolting on tremendous power. Cobra 3v heads? Sorry broham, all Cobra's were 4v. The 3v didn't come around till 05 and was the standard in all GT's. Unless you port the 3v heads they will flow worse than the 2v heads, and using the 4v heads will improve power up top, but will sacrifice low end. In the end it's better bang for the buck to just do a full PI swap. Thanks for posting it to clear that up for him. I've been around the modular motors and mustangs for quite sometime so I knew his information was inaccurate, and it also wouldnt be my first PI swap either lol. But I didn't feel like wanting to correct it.. so thanks I hear that man, I've had 7 fox cars (4 SBF's, 1 SBC, 1 BBF, 1 4.6L), 2 5.0 SN-95's, 2 4.6 and 1 5.4 SN-95, a 2002 GT, a 2003 Mach 1, and a few misc parts Stangs here and there in my short life. Before my bike and car audio obsession Mustangs were my thing haha. Build is looking good! -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
corona_jeff Posted June 25, 2011 Report Posted June 25, 2011 Well for today the foam was glassed over, and baffles put in.
Slapuhho Posted June 25, 2011 Report Posted June 25, 2011 You don't fuck around sir. 4 18's, low power and lots of gay fur. Team gg Team DOA My Videos
uhoh_45 Posted June 25, 2011 Report Posted June 25, 2011 both back pieces there are 1 sealed section yes?? and sub will be inverted correct? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
corona_jeff Posted June 25, 2011 Report Posted June 25, 2011 both back pieces there are 1 sealed section yes?? and sub will be inverted correct? Yes the back is a split baffle thats a single sealed chamber. A full baffle wouldnt fit due to the opening. The seam will be glassed over.
uhoh_45 Posted June 25, 2011 Report Posted June 25, 2011 makes sense - now get back to work R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
