Make a single cab loud without a blowthrough?
Is it bucket or bench seat? If bucket can u make box in center.not sure what class you be in? Just idea
This. If no buckets, go to junkyard and get buckets.
i would do a single drivers side captain seat and build an enclosure in the passenger side, lol
Ok, I guess I'm gonna take this on as my new challenge: to do a 150 in this truck without a blowthrough and without removing seating area. Buckets are an option, but not building a center console/sub box. The truck has to remain functional.
:foshizzle: good luck with that bro.
single 15 in the center mounted inverted... might fit an 18 but 15 is more likely. Cut a hole in the back of the seat for the magnet to stick through ; ) put two ports on each end of the box facing up towards top of cab. Stuff a spacer between seat and back wall of the cab to make ports more "open" for metering. Should do well i'd think...
Would be a good idea to attach box to back wall of the cab and add external reinforcements as well to reduce body flex. I hear tennis balls between back wall of the cab and the box of the truck help a bit.
Hammerdown... 1%
i havent got mine metered yet , but I am running around 1200 to the re sxx.
My seat is all the way back its just the passenger seat that has to sit up close and cant really lean back.
SOLD
2006 Ford Ranger Single Cab
2 DC XL 15's
2 Crescendo BC2k's
4th Order Blowthrough
CURRENT
2012 Dodge Charger R/T
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
  • Who's Online   0 Members, 0 Anonymous, 941 Guests (See full list)
