i want to know if the btl 18 new design can handle 4000 rms. it will be powed by the cresendo audio 3500d. witch puts out close to 4000 rms a@ 1 ohm with correct amperage and voltage.
oh ya lol
the btl n2 12 can handle 3500 all day
just be careful
1994 Jeep Cherokee
!@#$%^&*(Soon to come)*&^%$#@!
TONS AND TONS of Audio Technix 80Mil
1 x 270 Amp Mechman Alt
1 x AQ3500D.1
1 x Rockford Fosgate T600-4
8 x Rockford Fosgate T2652-S
2 x XS Power D3100
1 x XS Power D3400
1 x eKs Kable 2 Channel Silver Plated RCA 5M
1 x Knukonceptz Kolossus Fleks Kable 1/0 Red 50FT.
1 x Knukonceptz Kolossus Fleks Kable 1/0 Black 50FT.
4 x Avenue - A605
2 x Fi Q 18
it will handle that if scoped correctly plus you wont be giving it 4000 after rise even if you can keep 14.4
dont start with the rise topic. but yes the woofer will handle the amp fine as long as the signal is kept clean.
If you have to ask the question then I wouldn't recommend doing it. Is the woofer capable of handle the power? Yes it is but only if the user knows how to properly use the power.
There is no "best" woofer, it all comes down to the install. If you don't know what rise is, you probably don't have the experience to run a 4kw system. What electrical upgrades do you have?
What about batteries?
