impedance rise?
What causes impedance rise in an enclosure and what will it do to output
i was going to ask about the same thing today ha. ill be watching to learn a lil too
The impedance is the resistance of the coil when AC is applied. Since the coil acts like an inductor, the impednace changes with frequency.
What people call impedance rise is due to the woofer being put in a box. If you look at the impedance plot of a woofer in free air, the impedance rises at the resonant frequency of the driver. Once in the box, the cone has a different reaction with pressure behind it, which can change the impedance plot. You also have new impedance spikes due to the box size, port tuning, etc.
Impedance rise may in fact not even be a higher impedance at all frequencies (more than likely will be an increase in the overall average, but the spike at the driver's resonant frequency may still be the highest impedance). Many times it is just additional humps/spikes in the impedance plot, or even changing of the impedance spike seen with the woofer in free air. For someone playing music, the additional humps/spikes will increase the average impedance seen while playing music. For someone burping at a single frequency, they need to know the impedance at their frequency to match the amp to the sub. There is a good chance the impedance will be higher near the frequency they burp at, since it not far above port tuning.
For the average person, ignore "impedance rise". The hardcore competitor uses the actual true impedance to his advantage to get all the power he can from the amps
Need an install? Hit me up.
[email protected]
a current moving inside and out of a magnet
heat
motion itself
box design
all create an added resistance to the power u are tryin to send
most of the time a larger box will yield lower rise, but thats not a rule/law
just some minor input
I remember that post. . . :)
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Fuck imp rise...i'm prolly gettin like 1500 watts right now!
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
Power at 4 ohms won't do shit.
At Fs you'll probably hit 30 ohms+
Like this: (8 ohm woofer plot by the look of it)
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 2347 Guests (See full list)
