Its a trap!
But if your serious, what is the problem?
Edited by Supercharged DDs
Nope no trap I just have a mac that wont run the program. Trying to figure out if the dimension I have will work. Trying to squeeze batteries, amps and a box big enough for an SMD is a pain in the ass.
I have 7.40ft3 gross airspace. I need a port with 16in2 per cube and tuned to 32hz. port height would be 18.75, width and length can be adjusted to get the port area and tuning needed.
Let me see if I can whip something up. Woofer displacement, bracing displacement please. Dimensions for use as well.
EDIT: Nvm, just realized I'm on mobile, no computer access at the moment. Torres needs to make a app!
.26 on the sub and say .5 for bracing. Dimension are a bit of a problem since the box is odd shaped.
Edited by CJ18
I just guessed for dimensions and the ports common walls, came up with this.
Thanks. Instead of using dimensions, you can just type in 7.40 in the desired gross volume box and figure the port from that to get an exact tuning. I would do it but have no way to use the program. Damnit I love my mac but it is fucking useless when it comes to this.
Torres needs to make a damn app!!!
  • Who's Online   0 Members, 0 Anonymous, 773 Guests (See full list)
