Am I nuts? Difference in class d and class a/b amps
BassJunkie
Ok....Maybe I'm crazy but to me a class a/b amp sounds different on subs than a class d and not in a bad way. Opinions? Class a/b almost seems punchier to me and class d is sloppier, not by a whole bunch and I've never tested side by side an a/b amp and a d amp from the same company but I'm just curious as to what you people think.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
If you have specifications for both amplifiers check out the damping factor. You are not crazy, class a/b amps will sound punchier because of the higher damping factor than class d amps.
2011 Ford Ranger Sport 4.0 v6
2 sundown audio prototype nsv4 15s
crossfire 4k wired to 0.4 ohm
15 banks of maxwell 3.0 caps @ 18v
triple alts (x2 us alt 250's, x1 singer 320)
153 at 23hz
Thankkkkkk you!
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Its not just dampining factor it has to do with how the whole output section is designed.
Yes A/B amps have better SQ than Class D. Class D has a much higher amount of distortion but as things evolve or have evolved over the last 12 years Class D is catching up.
The key to a class D design that has incredible SQ are the amps that have built in DSP switching devices. In Theory The Kicker Warhorse should have the best SQ a software writer can write and the 2 Brazilian amp companies should also have very good SQ because they use computer hardware to control the output section and that allows the switching to be incredibly fast. Faster than any mosfet available.
Some of my amplifier terms could be worded wrong but this is the jist of amplifiers to come.
EDIT; I guess the proper term would be a DSP microprocessor or a digital microprocessor implemented into controlling the output section of a Class D design.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
you, sir, just educated me.....thanks :drinks:
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
  • Who's Online   1 Member, 0 Anonymous, 683 Guests (See full list)
