I have an alpine Type R (600W version, running at 700W) in a selaed enclosure at 1.25 cubic foot, and i have a box that is ported and tuned to around 35Hz and is 1.6 cubes after port displacement, which doesn't leave much room for the type R, but if I were to invert mount it would that make any noticeable difference by eliminating the woofer displacement? and if I did invert it would I have to reverse the polarity?
well...if you invert the sub you also have to invert the polarity from 0 to 180..
it =maybe= would do a Db more but, its all in the box...
PS: inverted subs are cooler to look...
Edited by gally
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
I´ve tested inverted subs before and score was almost the same , it had a small displacement so the internal space of the box didn´t change much affecting the score, in other words, for a daily application you can invert it without any problems, do it!
There's also no real point in my opinion. You're not going to magically grow that much more volume by inverting the sub. Just my $0.02
I'm not looking for the DB at the moment, just how it sounds, I guess I'll just try both ways and see what I prefer, just out of interest what would happen if I didn't reverse the polarity with an inverted sub?
He's fuckin with ya ha ha! It won't blow up just not sound as good as it should inverting is for looks if you want to show off the basket and motor of the sub then go for it
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Man, I run type r's for years. I ran them normal, inverted, had the polarity reversed, and didn't reverse it. It won't make a bit of difference to the ear, or on a db meter for that matter. So, the only reason why you would do it is for looks.
  • Who's Online   0 Members, 0 Anonymous, 2058 Guests (See full list)
