fmedina Posted June 5, 2011 Report Share Posted June 5, 2011 aq's site doesnt state it but whats an optimal tuning for a hdc3 10"? 35hz still good? Link to comment Share on other sites More sharing options...
Louisiana Bass Posted June 5, 2011 Report Share Posted June 5, 2011 The AQ HDC3's are alot like the DD 3500 series, and I know the DD 3500's like tuning a bit higher, around 37 hz. They can still play lows quite well too. N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
blownengine Posted June 5, 2011 Report Share Posted June 5, 2011 I don't tune above 35. 2 hertz won't make much difference anyway. 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free) Link to comment Share on other sites More sharing options...
AI James Posted June 5, 2011 Report Share Posted June 5, 2011 The AQ HDC3's are alot like the DD 3500 series, and I know the DD 3500's like tuning a bit higher, around 37 hz. They can still play lows quite well too. specs really arent close. aq HDC310-A HDC312-A HDC315-A HDC318-A Woofer Size 10" 12" 15" 18" Fs 41 Hz 43 Hz 38 Hz 31 Hz Sd 33m M2 53m M2 89m M2 119 M2 Krm 11.76 mOhm 12.443 mOhm 12.686 mOhm . Erm 0.881 0.88 0.875 . Kxm 113.942 mH 118.004 mH 144.352 mH . Exm 0.667 0.664 0.628 . Vas 9.168 Ltr 20.99 Ltr 70.421 Ltr 109 Ltr Cms 59.3 uM/H 52.64 uM/H 62.609 uM/N 54 uM/N Mmd 239.556 g 251.649 g 253.635 g 457 g Mms 243.003 g 258.665 g 268.902 g 481 g BL 24.114 TM 24.567 TM 22.39 TM 24 TM Qms 6.999 7.313 7.405 3.3 Qes 0.374 0.305 0.444 0.5 Qts 0.355 0.375 0.419 0.464 Sensitivity 1W/1m 84.439 dB 88.172 dB 91.532 dB 89.8 dB Magnet Diameter 8.7" 8.7" 8.7" 8.7" Magnet Weight 340 oz 340 oz 340 oz 340 oz Coil Diameter 3.0" 3.0" 3.0" 3.0" Coil Length 2.135" 2.135" 2.135" 2.135" Useable Throw 3.0" 3.0" 3.0" 3.0" Continuous Power 1000 W 1000 W 1000 W 1000 W Music Peak Power 2000 W 2000 W 2000 W 2000 W Mounting Depth 7.625" 8" 8.875" . Circle Cutout 9.4375" 11.375" 14.0625" 16.50" Model HDC310-A HDC312-A HDC315-A HDC318-A DD 3500e Voice Coil Diameter 3" Magnet Weight 240 oz Power Handling RMS/Peak 1200/4800 Suspension Travel 80 mm Nominal Impedance D .5, D .7, D1.0, D2.0, D4.0 Ohm DC Resistance D .5 - 3.6 Ohm Model 3510e 3512e 3515e 3518e Rec Box (cubic ft) 1.5 2.5 4 6 Port Area (sq in) 24 40 64 100 Port Length (inches) 23 22 21 20 Woofer Diameter 10" 12" 15" 18" Free Air Resonance 33 Hz 32 Hz 30 Hz 27 Hz Qts 0.35 0.36 0.38 0.641 Qes 0.38 0.39 0.41 0.716 Qms 4.33 4.81 5.05 6.169 Vas 18L 40L 112L 122.6L Sensitivity 86.5 dB 89 dB 92 dB 93 Shipping Weight 33 lbs 35 lbs 37 lbs 42 lbs mmm Nope Link to comment Share on other sites More sharing options...
Louisiana Bass Posted June 5, 2011 Report Share Posted June 5, 2011 Eh, my bad... Just tune to 35 and be happy N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
AI James Posted June 5, 2011 Report Share Posted June 5, 2011 depends what your looking for. Id honestly with that sub tune to about 38hz and let it roll off. Link to comment Share on other sites More sharing options...
korey_hofer Posted June 5, 2011 Report Share Posted June 5, 2011 small chamber 1.25ft big port 25'' tune low 33hz from some one who has used them before previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street. Link to comment Share on other sites More sharing options...
fmedina Posted June 5, 2011 Author Report Share Posted June 5, 2011 sweet thanks guys. i know cone area has a part in playing low but the 3510 fs is lower than the hdc310. does that mean the dd will play lower tones better? or all depends in the box really Link to comment Share on other sites More sharing options...
fmedina Posted June 5, 2011 Author Report Share Posted June 5, 2011 small chamber 1.25ft big port 25'' tune low 33hz from some one who has used them before have a design you could share?? torres numbers? Link to comment Share on other sites More sharing options...
AI James Posted June 5, 2011 Report Share Posted June 5, 2011 naturally the DD will play lower but as always the box always plays a roll Link to comment Share on other sites More sharing options...
