DC Sound Lab
I plan on getting 4 level 3 10's for my car soon and they will be powered by either a sundown SAZ-2500D or a Rockford 2500. I designed this ported box for them with 2 subs on each side with 1.8 cubes after displacement per 2 subs. The problem is when I put the numbers into WinISD to tune the port to around 30 Hz with 30-40 sq inches of port area it tells me I need a 40-50 in port. Is there any way I can fix this?
I can give you the dimensions for my box if you want them. The subs are staggered diagonally on their baffles because i didn't want this box to go too deep into my trunk. The two baffles are at a 30 degree angle from each other.
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
You'll probably have some cancellation. How much space is between the closest pair of subs that are on opposing sides?
Have you just considered a 4th or 6th order?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Thanks the torres box calculator is working way better!
The subs are about 2 inches apart but the way they are staggered most of the sub is aimed at the baffle of the other side. i was considering a 4th order but I dont have the room for it
Build Thread
UBL
1948 Plymouth
I can go 34" wide, 19.5" high, and about 16" deep but maybe an inch further if needed
Build Thread
UBL
1948 Plymouth
Its hard to figure out if this configuration would work for you but with 10s and your dimensions I think it would. This is the box I have in my truck now for 4 Xl 15s. You could either port at the bottom under the 2 middle subs or port firing up centered on the back of the box.
I'll see if i can design a box like that to fit my car.
Build Thread
UBL
1948 Plymouth
how do you think these subs will do in a fourth order? i can do it with 2 sealed chambers at about 1.5 cubes net and a center ported chamber at a little less than 1.5 cubes net with a port tuned to 45-50
Build Thread
UBL
1948 Plymouth
  • Who's Online   0 Members, 0 Anonymous, 5023 Guests (See full list)
