i have a 99 dodge avenger and for some reason every-time you open either door the headlights will start slashing for like 3-4 minutes. also when this happens i can hear a relay clicking under the hood?
bad relay maybe
05 Ford F150 Single Cab
Audio:
-Pioneer DEH-3200DVD
-Hertz Hi-energy 5x7 Front
-RE Audio 5x7 Rear
-DD 2512 in Custom 40 Hz Box
-Eclipse EA4100 High/Mid amp
-Eclipes XA1000 Sub amp
-Audison Connnection RCAs
-Random wire:Kicker,RF,Lightning Audio
i took em all out one at a time and it was still clicking and i could feel it in the relay box the only one that stops the flashing is the headlight relay but it still clicks
I would ensure that you tagged the correct wire for the lights. I believe on that car it's a negative pulse wire. It's red and should be at the headlight switch itself.
2010 Altima Coupe
Kenwood DNX9990HD
JL C5 components
Rockford T1692's
JL HD600/4
JL HD 750/1
JL 12W7AE 2.5 cubes @ 33hz
Alarm is going off?
the relay clicking under the hood is the relay for your lights. they are flashing because the alarm is telling them to. if the siren/horn isnt hooked up and the alarm is going off, the only indication that the alarm is triggered is the lights flashing.
Edited by EVAlonSo
