jconnway Posted June 13, 2011 Report Share Posted June 13, 2011 I had a chance to pull parts off a mint 2.4 L TSX engine the other day, and for those who don't know, the motor is basically identical to the 2.4 in the Honda Accord. The TSX has a bigger Intake manifold and different gaskets, injectors, ect. but basically the parts are interchangeable. So for 100 bucks I scored the entire intake manifold, all the P2R thermal gaskets and a P2R throttle body spacer. I'd love to install the spacer, its red, and will probably increase air flow slightly, and even if it doesn't, I like the whistle noise it makes. The problem i've run into, however, is that installing a 3/4'' TB spacer moves the throttle body upwards 3/4 of an inch, and my K/N CAI has no where to go. So I think the only option I really have here is to cut (I know it sounds stupid) about 3/4" off the bottom of the K/N pipe. It sucks to cut up something you just paid for but I don't really see other options. The K/N CAI is made for the car with its TB at stock position. What do you guys think? Would you cut your IM for a TB spacer? (BTW, on this particular engine, the addition of the P2R spacer and two thermal gaskets yields a 4 HP gain on the dyno, which is incredible for a 20 dollar mod, so if your gonna say "don't waste your time its not worth it", dont, lol) Quote Full Pioneer Build 4 Per Door - Front Door Build Up Link to comment Share on other sites More sharing options...
white4d96 Posted June 14, 2011 Report Share Posted June 14, 2011 Don't waste your time it's not worth it. Where does the pipe not fit? I think chopping 3/4" wouldn't be an issue but depending on what your issue is you could possibly tweak other things in the way, or if there are couplers used, replace one with a differently-angled coupler to give yourself the clearance. Just a couple thoughts. Quote Too many projects, too little time... Link to comment Share on other sites More sharing options...
OrionStang Posted June 14, 2011 Report Share Posted June 14, 2011 I want to see proof of this 4 hp, especially on that engine. On topic, you may get some help from K&N if you call up tech support. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
n8ball2013 Posted June 14, 2011 Report Share Posted June 14, 2011 OI know on my truck they say that the K&N will not work iwth a throttle body spacer. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
3Ltriste13 Posted June 25, 2011 Report Share Posted June 25, 2011 i got an airaid cold air kit and a spacer and my truck i dong know how many ponys i got out of this 400$ investment but it feels a lot more torqey on the bottom end like from 1500 to 2500 rpms. And the spacer gave it a nice lil wine to the truck too. but its you money i liked it dosen't mean youll like it. Quote YEEEEEEEEEEEEE Link to comment Share on other sites More sharing options...
3Ltriste13 Posted June 25, 2011 Report Share Posted June 25, 2011 (edited) the tornado works the same and it cheaper. Edited June 25, 2011 by 3Ltriste13 Quote YEEEEEEEEEEEEE Link to comment Share on other sites More sharing options...
white4d96 Posted June 26, 2011 Report Share Posted June 26, 2011 Tornado doesn't work. It's more restriction which the engine doesn't need. Quote Too many projects, too little time... Link to comment Share on other sites More sharing options...
SR20DAZE Posted June 26, 2011 Report Share Posted June 26, 2011 I dont see the trimming as much of a problem. As for dyno numbers. They are so easy to manipulate. But for thr money you spent why not try it? It should reapond better Quote Hahah damn cody She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch. you dont find dubstep, dubstep finds you hu: Pioneer MVH - P8300BT mids: Alpine sps-600 all four corners highs: Addictive Audio ECST25A,Memphis PR tweeters back sub: 15 inch crossfire bmf box: 4 cubes at 38 hz amp: Rockford Fosgate Power 1000 25 To Life 140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q) Build Log http://www.stevemead...ima-56k-beware/ Feedback http://www.stevemead...s-bfd-feedback/ Link to comment Share on other sites More sharing options...
jconnway Posted June 26, 2011 Author Report Share Posted June 26, 2011 I'm putting it in this week. Just did headers. big increase. Quote Full Pioneer Build 4 Per Door - Front Door Build Up Link to comment Share on other sites More sharing options...
csill420 Posted June 26, 2011 Report Share Posted June 26, 2011 Getting a throttle body apacer is going to increase the velocity of air going into ur intake manifold which will decrease the time it takes for the a/f ratio to enter the combustion chamber. Cutting material off the intake system shudnt be a problem, the throttle body spacer will. Replace that 3/4 chopp. Also give u better fuel economy and a slight increase in torque. Dont bother adding an intake or tbs unless u have an aftermarket exhaust system. U have to match increase intake u if u dont u will loose power due to exhaust gas restricion leaving the cylinders Quote Fuck warning points. Link to comment Share on other sites More sharing options...
