As some of you know, i am using these in my Towers and i get asked over and over again what a Passive Radiator does. Instead of trying to explain it or say "google it!" i figured i would just google it and let the info do the talking.
googled, copied, pasted for your knowledge.
Passive Radiators
Passive radiators (PRs) are sometimes thought to be a bit "sneaky" by owners who take their speakers apart to examine them in the case of damage or deterioration. Why is this? Because while they look like, and even sound a bit like, normal powered woofers from the "outside," from the inside they are different. They are not hooked up to the speaker wiring, and they do not have magnets mounted on their baskets (if they even have baskets at all). Some manufacturers or salespeople even take advantage of this appearance to imply that the speaker has a larger woofer than it does (most times PRs are larger than the active woofer in the speaker) or that it has two woofers, creating in the customer's mind the impression that the speaker will have stronger or louder bass because of this. Not that bigger woofers, or even more woofers, will do this!
So what are passive radiators, what do they do, how do they work, and what are the pros and cons of using them?
1. A passive radiator is essentially a weight on a spring. The weight is the combination of the cone material and whatever mass loading might be used - this is the critical part of PR design and must be correct for the part to function properly. The spring is partly the stiffness of the suspension materials (which are usually quite flexible), and mostly the air trapped inside the cabinet. (Later I will mention the passive radiator system as a sub-class of all "vented" systems. They are mathematically identical, the typical vented system using a "port," or hole in the box, with a tube attached to it, to create the "mass and spring" effect - the mass being the air column in the tube)
2. A passive radiator is tuned (by the mass loading) to resonate, like a tuning fork does when its tone is played on an instrument, at a frequency below the active woofers linear response range. Unlike the tuning fork, which is designed to resonate very loudly at one specific frequency, with a response which falls off very rapidly above and below it, a PR will respond to tones on each side of its resonance with a carefully controlled roll off. These are typically 18 dB/octave slopes, which while pretty steep, give the device a useful range of about half an octave.
As I said, this tuning is below the "normal" response range of the active woofer. All woofers, as the frequency gets lower and lower, eventually make less acoustic energy (noise, or music if you are tasteful!). The frequency at which they start to drop in output is usually described by a slightly lower point, called the "-3 dB" point. This is the frequency at which the woofers output is 3 decibels lower than the typical pressure it produces over its usable range. By tuning the PR so it becomes excited at a frequency below this, it contributes to the systems total output by adding about a half octave of bass extension to the speaker. Its tuning is such that at any given point, the combined output of the passive and the woofer adds up to the level produced by the woofer on its own at higher frequencies. Of course, below the PR's resonance, reponse falls off pretty sharply, but "between" that resonance and the woofer normal roll off point, is a small amount of bass extension in a range where otherwise the response would be much lower.
3. It may seem logical that the passive would operate somewhat like a lever, with its cone moving out at the same time as the woofer cone moves inward, and vice versa. This is not the case, however. In fact, both cones could move in or out together (this is called "in phase"), or any combination of opposite motions ("out of phase" - the most extreme being "180 degrees" out of phase - like the lever effect described above). Ideally, in order to reinforce each others sound, they would be exactly in phase, but in reality, due to the physics of this sort of resonant system, they are out of phase to some degree most of the time.
It is also interesting to note that at the resonant frequency of the PR, its motion is at a maximum (this makes sense of course), and the woofers motion is at a mininum!
4. This is one of the advantages of this type of system - it takes the burden away from the (typically) smaller diameter woofer of producing the lowest tones (which require the most air movement to be equally loud) and shifts it to the larger diameter PR, which often also has a suspension capable of greater linear excursion (motion in and out). Another obvious advantage is that the point at which the bass response starts to drop off is lower, giving a more extended linear bass response to the system. Also, it can allow the use of a smaller diameter woofer, which results in more accurate and better dispersed response at the other bass and low midrange tones.
5. Unfortunately there are some drawbacks as well. One, alluded to above, concerns the "phase response" of the woofer-PR system. Ideally, all the frequencies produced by an audio system (and the chain of recording gear ahead of it) will be in phase. This means that the compression phase of a wave (see "What is Sound") in the recording environment will result in a compression phase in the listening room, at any and all frequencies. It has been found that so long as the overall phase response does not contain any sudden changes or discontinuities, the human ear/brain system will not notice or be bothered by it. However, when the phase response changes rapidly over a small range, it can be noticeable - some people are more sensitive to this than others. The very nature of the resonant system employed results in phase problems of this nature in this narrow range of tones.
Another problem is that due to the fairly sharp tuning of the PR, that is the way its response falls off rapidly above and below its tuned resonance, the frequencies below its tuning will roll off very rapidly - and in addition, the air in the speaker box no longer acts like a spring to control and restore the motion of the PR and especially the woofer. A woofer in a sealed enclosure (see What is Acoustic Suspension) moves less and less at lower frequencies, because it cannot compress the air in the cabinet enough to move in and out very far, and so it will not tend to "tear itself apart," or produce unwanted high levels of distorted signal as it moves out of control.
An acoustic suspension system also tapers off in its response at only 6 dB per octave. The vented, or passive radiator, system rolls off at 18 dB per octave and thus produce very little usable bass below its resonance - and what it does produce can be rather distorted.
For these two reasons, vented systems in general are a poor choice for small speakers that roll off much above 40 Hz - there is too much signal present,in the range they respond to poorly, for them to work well. A larger speaker will work better with this sort of set up because at the frequencies that might be troublesome, there is rarely any musical signal present.
Here is a typical Passive Radiator:
Follow my Tweet (Twitter)
Passive radiator (speaker)
From Wikipedia, the free encyclopedia
Passive radiator enclosure with front mounted passive radiator; back or side mounting is also used
A speaker enclosure using a passive radiator usually contains an "active driver" (or main driver), and a "passive cone" (or drone or passive radiator). The active driver is a regular driver, and the passive is typically the same or similar, but without a voice coil and magnet assembly. It is only a suspended cone, not attached to a voice coil or electrical circuit. The passive radiator usually has some means to adjust its mass, thereby allowing the speaker designer to change the box tuning. Internal air pressure produced by movements of the active driver cone moves the passive radiator cone as well.
Passive radiators are used instead of a reflex port for much the same reasons—to tune the small volume and driver for better low frequency performance. Especially in situations in which a port would be inconveniently sized (usually too long for practical box configurations). They are also used to eliminate port turbulence and reduce motion compression caused by high velocity airflow in small ports (especially small diameter ones). Passive radiators are tuned by mass variations (Mmp), changing the way their compliance interacts with motion of the air in the box. The weight of the cone of the passive radiator should be approximately equivalent to the mass of the air that would have filled the port which might have been used for that design. Passive radiators do not behave exactly as do (more or less) equivalent bass-reflex designs in that they cause a notch in system frequency response at the PR's free air resonant frequency; this causes a steeper roll-off below the system's tuned frequency Fb, and poorer transient response. Due to the lack of vent turbulence and vent pipe resonances, many prefer the sound of PRs to reflex ports. PR speakers, however, are more complex to design and likely to be more expensive as compared to standard reflex enclosures.
The frequency response of a passive radiator will be similar to that of a ported cabinet, with two exceptions. The system low frequency roll-off in a passive radiator design will be slightly steeper, and will have a notch (dip) in frequency response due to the Vas (compliance, or stiffness of the speaker cone) of the passive radiator. The goal in designing a passive radiator is to adjust the tuning so that this notch is below audible levels.
interesting read. Thanks.
2006 Nissan Z Track.
My Feedback Thread
iv read all that before, after you started your build, shit is weird lol interesting but to much thinking for me.. then again im retarded :drink40:
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
Steve go get those weights for your passive radiators dammit lol :)
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
All thank you steve for taking in a consideration of my post :wub:
:lol: :lol:
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
Good Stuff :)
Haha, I was thinking recently, but not sure if it would work;
Say you buy two subs, but are only able to power one (e.g. your amp only has 1 channel, or you want a seconds one because your amp only has one channel with a decent power output), so for the mean time, while you only have 1 amp powering one sub, the other (if it is in the same box/enclosure and isn't isolated from the other one) sub can act as a PR? Even though it will still have VC's and a magnet, I just thought that it may work :P
Probably a stupid idea, but meh, just a thought I felt like expressing.
04 Lancer CH ES
JVC KD-R626 H/U
(2) JL Audio Evolution C2-650 Components
RE Audio SEX 12" D4
JL Audio XD 600/1 Monoblock
  • Who's Online   0 Members, 0 Anonymous, 3362 Guests (See full list)
