If you dont mind me asking why do 2 separate boxes?
We built two seperate boxes for my buddies 2000 xterra just for the fact that it's easier to move and work with a 2 12 ported box than a 4 12 ported box.
and single chamber boxes have proven to be louder. ;)
hopefully you'll haev better luck with what im assuming are soundigitlas than any of the other guys.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Should make for a strong box once bracing is added. Having 2 separate boxes should be better for bracing aswell. Peices don't need to be as long therefore stronger.
Good idea. Looks good too
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Updates ?? :popcorn:
Pioneer deh-80prs2 10" Tantric Sounds HD's Ported Box Tuned to 33hzSoundqubed 3500.1Hertz HSK 165Tantric Sounds 6.5" Coaxials80sq ft of MurdermatXs Power D3400 & D3100
Sky High Car Audio Cable Throughout
  • 3 weeks later...
single baffle? two 16ks on one 300 amp alt?? :shrug:
either way im tuned in
but this does remind me of a similar build also...
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Roflmao I know what you mean..
OP, tuned in to see results. How does it sound? :)
this will be interesting on a single baffle but the top and bottom of the box is so tight the subs mounting to them, also there is a 2x2 brace between the subs along with the rods.
i have no choice on the alt issue. no space what so ever. i got the same response when i ran a 11k amp on stock alt and no big 3 which i did fine on. im relying on battery bank which wont be up to par. ill have to watch my voltage. on the alt issue even if i had the space all i could do is charge batts faster on a multiple alt set up.
yes. this is a very similar build to a fellow member here on the site but not as extreme. im not trying to copy him. im just playing the cards i was dealt and im not complaining on what i have to play with.
