Well, as promised, I finished my box, here are the pictures:
It sounds nice in my little celica :)
Things to do:
Try to clean up the port a bit
Get better amp, the xplod is getting extremely hot
Weld in supports to the seat to mount the box to, to help prevent theft, and movement
Thank you guys for all of the help you have given me, I really appreciate it, wouldn't have gotten this far without you :)
What is that thing tuned to? Also a suggestion I can add is when you clean up the port, sand the corners down like you took a router bit to it.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Tuned to 40.5hz, my first box I decided to go with the manufacturer recommended tuning. As for the port, you mean basically flare it out?
Make the edges smoother by sanding them down.
Does having a small port affect anything? As long as I use the port calculator and make the length correctly?
The length isn't everything you need the right amount of port area for proper tuning.
Edit: Area = LxWxH
Edited by DjCrush
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
