buy a second amp the same, and strap them into 2ohm?
that's what I was thinking, but I really don't have 700$ to drop on an amp right now
one thing that makes me wonder though...if I'm wired to 1 ohm, and dropping below that obviously I don't see why it would be protecting?
the amp is stable at .5 daily, and .25 for burps. How low could it be dropping for it to protect? I guess I don't know a whole lot about impedance rise/drop.
Edited by crav1n
i cant remember any reasons why im so against .5 for a daily driver....... better hope you didnt crispy anything inside it. or close to crispy.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
that amp will take .5 no problem
what I'm confused about is how your sitting one ohm even dcr should be less than 1ohm wired at .5 nominal.
take all the subs out and re wire the box making sure the phase is correct on each sub and making sure none of the coils got labeled backwards from the factory
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
that's what confused me as well. flat wall was sitting pretty at .5ohm final load.
he should be re-wiring everything today. he has all his 8 gauge wires running to the back where they all get spliced and connected to one 8 gauge wire that goes into the amp which is my guess for why it's sitting high (or least part of the reason)
hiiiiiiii
2002 4runner - buncha speakers n amps n shit (gone)
1994 astro - more stuffz
update: pretty sure all the pic links in the logs are broken lol.
ma slop garb build log
16 12's 4th order
4runner rebuild in progress
clickkk meeeee!!!! 4 18's 6th order
UBL - clicky
http://www.youtube.com/yyj11589
lots of hater kids here. Pay no attention, they just want 89,000 watt subs for 3.50
If you would have put a dc dustcap on it and called it lv your mom, they would all be in love
he could have a coil on the way out. he could have a DMM that sucks and has high resistance in the probes as well.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I'll try a different dmm today. And to theydontwantmusic, I never said it was rated at .5, I said it was stable at .5. meaning I've played it at that level, along with many other people, all day long
idk I guess though
so I tested my leads of my dmm today, and I'm getting a reading of .5-.7 out of them. So if I am wired at half ohm, and my leads are adding .5-.7, does that mean it's just my multi meter? that still doesn't explain why I'm not seeing hardly any voltage drop at full tilt though? I'm gunna test my voltage later with a dmm to see if maybe something is wrong with my stinger volt meter...
those stinger meters are notorious for being garbage.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
