corteznewbie Posted June 27, 2011 Report Share Posted June 27, 2011 whats the max voltage a 96 jeep grand cherokee with the 5.2 can take? i been thinking about switchen over to a 14 volt batteries Quote Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted June 27, 2011 Report Share Posted June 27, 2011 well, generally a vehicles electrical can only go up to 15volts (cars actual electrical). An alternator can go up to like 18 or 19v. Thats why you always see 16v systems having 1 alt with a step down to power vehicles stock electrical items(AC, power windows, locks, etc.). Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
BassMunky Posted June 27, 2011 Report Share Posted June 27, 2011 any links to specs on cars? Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
corteznewbie Posted June 27, 2011 Author Report Share Posted June 27, 2011 right now i have a adjustable volt reg and would like a 14 volt batts to keep voltage drops low Quote Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
MECHMAN Posted June 27, 2011 Report Share Posted June 27, 2011 right now i have a adjustable volt reg and would like a 14 volt batts to keep voltage drops low Look at the video in our other thread, you can do the same thing in your Jeep that we did in our TJ. Charging @ 16.5 is just fine with the correct batteries. 16v batteries require an 18.5-19.5v charging that is too high, it will blow bulbs and such, but the 16.5-8v charging of the 14v system works just fine. We run that in the Jeep, Silverado, Mustang, S-10 and countless customer vehicles with zero problems to date. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
corteznewbie Posted June 27, 2011 Author Report Share Posted June 27, 2011 right now i have a adjustable volt reg and would like a 14 volt batts to keep voltage drops low Look at the video in our other thread, you can do the same thing in your Jeep that we did in our TJ. Charging @ 16.5 is just fine with the correct batteries. 16v batteries require an 18.5-19.5v charging that is too high, it will blow bulbs and such, but the 16.5-8v charging of the 14v system works just fine. We run that in the Jeep, Silverado, Mustang, S-10 and countless customer vehicles with zero problems to date. so i can get 14 v batts and use mt adjustable volt reg to bypass the ecu regulator and then save up for a mechman alt. now does the mechman regulator bypass the ecu regulator to? Quote Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
AA98hoe Posted June 27, 2011 Report Share Posted June 27, 2011 yes an yes you set your reg to charge at 16.8 and you should be fine Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
Ray Posted June 27, 2011 Report Share Posted June 27, 2011 Make sure to set when its cold. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz Link to comment Share on other sites More sharing options...
MECHMAN Posted June 27, 2011 Report Share Posted June 27, 2011 Yes, set it cold with a load (headlights, fan on) and the rpm up to about 1500. The Mechman unit handles it's own regulation. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
corteznewbie Posted June 28, 2011 Author Report Share Posted June 28, 2011 so will it set off the charge light on my dash? its a old jeep so not worried bout any warning lights. its my comp ride i'm adding on lil by lil Quote Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
