Ah I stand corrected /\/\ :ninja:
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
So 6" away for best results. That's what I figured, just wanted to clear it up... So 14" long would give me 5.5" away from the back wall, sounds good to me. You say 4 6" aeros 14" long a piece will give me 32hz tuning and 13cubes? Would the 4 6" be enough port? I can always add extra 2x4s for bracing to take up a cube or two.
Also, how does removable aeros work? I'd like to have a low tuned daily setup and be able to switch it up for comps :)
Thanks so much for the help y'all, I truly appreciate it!!!
As far as making them removable, you can use gorilla tape to attach the inside flare to the tube. To remove them, you would need to remove a sub first and take it apart and slide it out.
For port area, it is near the smaller end of the spectrum, but should still work well. Most the time, you can use less area with aero's than a standard port.
SMD Super Seller
My Feedback Thread
Sounds like a good deal! Thanks for the help man... One last question, where can I find some good 6" aeros? I've looked on Darvex and Parts Express, didn't see any, but may have missed it. Direct link me to ones you would recommend, if any :)
Damn, near $40 each... Need to see how funds look, got paid today but trying to save for an amp...
Anyways, mucho gracias mate :D
If you remember, please let me know :)
