Rebel4055 Posted July 1, 2011 Author Report Posted July 1, 2011 It's a Jensen flipout, not sure on the model number but everything is flat. Bass boost on the amp is off, forgot to mention that. Haven't got a chance to check voltage at the amp so I was going by the dash gauge. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
ingramcaraudio Posted July 1, 2011 Report Posted July 1, 2011 It's a Jensen flipout, not sure on the model number but everything is flat. Bass boost on the amp is off, forgot to mention that. Haven't got a chance to check voltage at the amp so I was going by the dash gauge. If you have a bad ground it won't show up on the dash gauge because it wont be affecting the battery it will only affect the voltage at the amp. Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts
billy101 Posted July 1, 2011 Report Posted July 1, 2011 It's a Jensen flipout, not sure on the model number but everything is flat. Bass boost on the amp is off, forgot to mention that. Haven't got a chance to check voltage at the amp so I was going by the dash gauge. If you have a bad ground it won't show up on the dash gauge because it wont be affecting the battery it will only affect the voltage at the amp. x2...a bad ground will let the amp work, but not work well. I had a shitty ground in my friends car and his voltage was dropping horribly when it shouldn't have...moved the ground and it was much better. First System 2002 Impala LS 3.8L V6, 128,365k miles. Alternator: DC Power 190Amp H/O Alternator Headunit: Kenwood KDC-BT945U. Speakers: MBQuart 6.5" Comps, 6x9 3-way. Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm. Box: 3.1cuft box tuned to 33hz. sealed off to cabin Big 3- done with all Knukonceptz KCA 0 gauge. Don't drop below 14.1v at full tilt.
Rebel4055 Posted July 1, 2011 Author Report Posted July 1, 2011 It's a Jensen flipout, not sure on the model number but everything is flat. Bass boost on the amp is off, forgot to mention that. Haven't got a chance to check voltage at the amp so I was going by the dash gauge. If you have a bad ground it won't show up on the dash gauge because it wont be affecting the battery it will only affect the voltage at the amp. x2...a bad ground will let the amp work, but not work well. I had a shitty ground in my friends car and his voltage was dropping horribly when it shouldn't have...moved the ground and it was much better. I'm working for his dad tomorrow evening so I'll grab a few tools and my DMM and check. I hope it will be a simple ground issue. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
Rebel4055 Posted July 2, 2011 Author Report Posted July 2, 2011 Alright update, I grounded the amp to the frame, shortened it up quite a bit. Was driving around for awhile and the amp got warm/hot but not like it was so I hope that fixed it. I also notice the durangos voltage is idling around 13.8 Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
18abVFL Posted July 2, 2011 Report Posted July 2, 2011 you know the circuits are bridged internally? if you have each sub wired at 2 ohms into each "channel", the amp will see it as a 1 ohm load. 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck)
kam311 Posted July 2, 2011 Report Posted July 2, 2011 you know the circuits are bridged internally? if you have each sub wired at 2 ohms into each "channel", the amp will see it as a 1 ohm load. But they are dvc 2 subs, not dvc 4's. So he can't wire each sub to 2 ohms, a single dvc 2 sub will represent a 4ohm load or a 1ohm load, then as a pair they will represent a 2ohm load or a .5ohm load. so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
18abVFL Posted July 2, 2011 Report Posted July 2, 2011 you know the circuits are bridged internally? if you have each sub wired at 2 ohms into each "channel", the amp will see it as a 1 ohm load. But they are dvc 2 subs, not dvc 4's. So he can't wire each sub to 2 ohms, a single dvc 2 sub will represent a 4ohm load or a 1ohm load, then as a pair they will represent a 2ohm load or a .5ohm load. ...touche 1999 Monte Carlo Sony CDX-GT34w 2 Alpine Type R 12"s in 4 cubes tuned to 35hz American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms) Stock alt, Stock batt, Big 3 Upgrade Boston s55- 5 1/4s (doors) Boston s95- 6x9s (rear deck)
kam311 Posted July 2, 2011 Report Posted July 2, 2011 you know the circuits are bridged internally? if you have each sub wired at 2 ohms into each "channel", the amp will see it as a 1 ohm load. But they are dvc 2 subs, not dvc 4's. So he can't wire each sub to 2 ohms, a single dvc 2 sub will represent a 4ohm load or a 1ohm load, then as a pair they will represent a 2ohm load or a .5ohm load. ...touche But either way if he wired it to .5 ohms by accident (kinda like what you were saying) that would be bad! But to ge honest I havnt heard very many "great" things about the prime series amps or subs so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
Rebel4055 Posted July 2, 2011 Author Report Posted July 2, 2011 I double and triple checked lol, they are wired at 2 ohms. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
