S15_Silvia Posted July 1, 2011 Report Posted July 1, 2011 What's up guys- my friend approached me, asking if I could install a Scosche in-line FM iPod controller into an '05 Impala with the stock Delphi CD deck. The car's owner is a 20 year old girl who doesn't want to learn how to use a new deck, so we kept it stock. But, there are issues with the accessory power in the car. There are just three wires to get the Scosche working- yellow +12v constant, red accessory, and a ground. Spliced those into the yellow, red and black wires in the Impala's radio harness, and weird shit happens. The radio will turn on, but won't make any sound. So we undo the accessory wire, leaving the black and yellow connected. Turn the key to accessory power, THEN touch the red wires back together, and boom, the iPod's sound comes through. It won't work properly when we start the radio with the red wires already connected. What's goin on? Do we need to tap a different wire for accessory power? Link to the Scosche: Here Thank you- hopefully we can get this thing working and make the owner happy. 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
S15_Silvia Posted July 2, 2011 Author Report Posted July 2, 2011 Teh bump 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
justcop Posted July 3, 2011 Report Posted July 3, 2011 Weird things happen with gms late models period when u screw with radio and don't get adapter. I have an 07. I would go under hood and run wire to fuse box which should have the fuses clearly marked on the underside of housing cover. Or hook up to constant power at box in kick panel with a toggle switch to toggle power on/off
n8ball2013 Posted July 3, 2011 Report Posted July 3, 2011 get your sources at the ignition column. make sure you fuse them. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
S15_Silvia Posted July 3, 2011 Author Report Posted July 3, 2011 This is what we did, as of this morning. (Didn't check the thread before then.) Tapped into the +12v of the nearby cigarette lighter, put in a toggle switch for that wire in the center console, and ran it to the accessory in on the Scosche unit. That way, she can tune the radio to 97.5, flip the toggle, and bam- listen to tunes. Are we cool with not fusing that connection? The cig lighter has a 10 or 15A in the fuse box. 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread
Louisiana Bass Posted July 3, 2011 Report Posted July 3, 2011 The fuse from the cig lighter should be fine. N8. No homo...unless you want there to be.
