Shigshwa Posted July 5, 2011 Author Report Share Posted July 5, 2011 (edited) Port area per foot needs to be at least 8..keep trying Hmmm, and simply adding more ports does not work, right? IT works but then you also have to take into account the space the ports take up in side the box. Then I have a big dilemma. More ports equal higher tuning. Can anyone figure out a solution? Or does this mean that I have to extend these ports out of the box? Nope gotta use more or bigger aeros. Why not port through the side? Aesthetic reasons. Edited July 5, 2011 by Shigshwa Quote Link to comment Share on other sites More sharing options...
Shigshwa Posted July 5, 2011 Author Report Share Posted July 5, 2011 (edited) Otherwise, the next thing I am thinking of is to simply scrunch up the port into a spiral, but I have no idea if that works. Argh, this pisses me off. It looks like I can't fit an 18 into this car then, and I really don't want to settle for a 15 either.. Edited July 5, 2011 by Shigshwa Quote Link to comment Share on other sites More sharing options...
Shigshwa Posted July 5, 2011 Author Report Share Posted July 5, 2011 I don't want to triple post, but here is the next option, lol Quote Link to comment Share on other sites More sharing options...
BJD3 Posted July 5, 2011 Report Share Posted July 5, 2011 Still need bracing. Quote Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert Link to comment Share on other sites More sharing options...
Shigshwa Posted July 5, 2011 Author Report Share Posted July 5, 2011 Still need bracing. I will add that after the whole port problem... Quote Link to comment Share on other sites More sharing options...
BJD3 Posted July 5, 2011 Report Share Posted July 5, 2011 Still need bracing. I will add that after the whole port problem... Depending upon how you brace it, you may still have a port problem... Quote Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert Link to comment Share on other sites More sharing options...
Shigshwa Posted July 5, 2011 Author Report Share Posted July 5, 2011 Still need bracing. I will add that after the whole port problem... Depending upon how you brace it, you may still have a port problem... How's that? Quote Link to comment Share on other sites More sharing options...
iKidwell Posted July 5, 2011 Report Share Posted July 5, 2011 2 12's is more motor force and only a little less cone area...i'd do that. or just don't do a wedge box...they complicate everything. Quote c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old. i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer. 2003 Infiniti G35 Sport Sedan Build in Progress Link to comment Share on other sites More sharing options...
Lbox88 Posted July 5, 2011 Report Share Posted July 5, 2011 (edited) It will add more displacement, lowering your net volume, increase your tuning, and rape your port values Edit: I am going through some of the same stuff but with 2 12's right now too, it's annoying as hell because I want to build my own also, not have some shop do it for me. Edited July 5, 2011 by Lbox88 Quote UBL | Build Log Link to comment Share on other sites More sharing options...
Louisiana Bass Posted July 5, 2011 Report Share Posted July 5, 2011 And for aeros, you'll want the end of the aero atleast 5 inches away from the wall it's facing on the inside. Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
