Hey what's goin on y'all? Just kinda had a random thought about it not hitting lows... y'all don't think it could be a LPF on the amp causing it not to hot lows do you? Nice box tho. At least I think.
- 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene
My Selling Feedback
Build Log
It really doesnt look like a bad box IMO. What power are you running to subs, and what are the box specs. It's not because it's a common chamber.
its like 50x21x26 i think, im powering with a hifonics brz2400 @ 2 ohms, so there getting 1700rms right now
Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi.
Audio: Two 10" Alpine Type R's ( 1000rms models )
Hifonics BRZ 2400.1D @ .5 ohm
Two Kinetic 1400 batteries ( soon to have XS power under hood )
Tsunami 1/0 Awg wire throughout truck.
Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine.
Exterior: 17"Dick cepek rims with 33" Toyo MT tires
Bushwacker fender flares
Magnaflow true duel exhaust
LED tail lights with Projector headlights
Plasti-dip fun coming soon!
Does the port end closer to the subwoofer that hits normally?
i don't think its the LPF, even if it is i can play with that any time and fix that, but really im trying to figure why they aren't hitting right, there in phase but not loading properly. and thanks the box is a little leaky untill i resin the inside.
yeah the port goes down 14.5" and goes in 11" , the sub that hits good is almost right above the uhm.. L shape of hte port? lol
That sounds like a definite loading issue, I'm almost 100% sure of it. Let someone else chime in though to be certain...
Pretty sure your only option to fix it, if it is a loading issue, is to build another box.
fuuckk sakes. lol. i avoided building that box for like 2 months as it was.. lol, it is probably a box issue though.. maybe ill look around and see if someone has a better design to help me out lol.
to help check if it's a loading issue, try to close the port off as best as you can and turn on some music. play it loud enough to where you think you could differentiate the two speakers. it might not work 100%, never tried, but to me i think that would help at least some
EDIT: or switch the subs and see if the issue continues with the same sub (then it's a sub issue) or if it's just the placement of the subs (box issue)
Edited by Torres
