2011 Chevy Tahoe, 10k watts, 4 Fi BTL 15s, 4 DC Power alts!
Looks good, but FYI, a pro tip from a :noob:. A bead of wood glue on the face of those tee nuts and you normally wont have that issue with them popping out. :werd_msword:
I knew there would be a trick like this, thanks. Luckily I can still do this as I haven't installed the subs yet (in fact I haven't even cut the carpet above the sub screw holes, lol).
I wonder if Gorilla glue would work even better seeing as the tee nuts are metal? Gorilla glue is the scariest stuff I own...
(Actually the thought of doing this to all 32 (almost 32, in a couple places I have to screw due to clearance issues) tee nuts now is a bit tedious, I will definitely do it if I happen to accidentally push one out though.)
I use either Titebond 3 or gorilla wood working glue. Isn't terrible but will probably take 10 minutes. Don't want to get glue in the screw hole and not be able to unscrew them. :lol:
Man those subs are going to love theIr new home lol. I thought u were going to make another top plate where the subs are to secure the two boxes together. Those boxes are sexy, you keep the great work rolling in.
The box(es) came out good. I actaully like how it looks with the strap going down the middle. It gives it a bit of contrast
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
nice build man,keep it coming :popcorn:
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
should be nice but why go with kicker when there are so many better amps out there. and gain matching and control of 4 amps is a pain imo. when you could do 1 big amp or 2 if needed. and my box is around 16 cubes and groundpounds daily with 4 18s. but its your build bro . maybe ill see u around at some shows even though you dont compete id like to hear it
Two reasons:
1. I started with two dual-1 ohm Fi BTL 15s I had originally planned to install in another car. When I got this car I bought two more dual-1 ohm Fi BTL 15s, but that left me with a setup that couldn't be wired to 1 ohm. So I had to find an amp or set of amps I could wire to 2 ohms. The Kicker ZX2500.1 was one of the few amps with a high power rating that can. One possibility was two 5000w amps at 1 ohm but I couldn't find much that was readily available (Sundown discontinued the SAZ-4500d right before I got this car).
2. The Kicker ZX2500.1 has an excellent rep as a reliable amp that does more than rated power, judging from the research I did. Couldn't find anyone with anything bad to say about it. They are not an "in-style" brand but seem to put out very solid equipment on the high-end now (Solo X is another example)
I see you're in Stockton! Let me know if you plan to come to any shows I'd love to see your ride.
another amp that might be good to get is the incriminator audio 40.1 and run it at .5ohm
people who have bought from me Team Bassick (ALPINE) Purplehaze nidus
head unit sony dsx-s310btx
subs 2 12 incriminator audio king of bass
subs amp incriminator audio 20.1
mids/highs
mids/highs amp incriminator audio 6.4
equalizer clarion
crossover interfire
alternator 1 mechman 240amp
battery's xs power 1 d2100 2 d3100
sky high car audio 1/0 awg ofc wires
memphis car audio 1/0 ofc
xs power xs flex 4 awg
sky high car audio 8 gauge ofc
sky high car audio 12 gauge ofc
t spec rca
check out my building log http://www.stevemead...frey-build-log/
http://www.stevemead...d-other-things/
check out audio gear i have for sale
http://www.stevemead...51#entry1595151
did your tahoe have the third row? if so how did you get the plastic peices off from around the third row mounts??
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
