Buzzing with A/C on
I don't know if it's RCA cables or not, but I don't remember this problem with my Kenwood headunit. Once that pooped on me I grabbed a Pioneer, and noticed the buzzing, then took that back and got an alpine on sale and notice the buzzing is still there.
Kenwood didn't have the buzzing, it stopped working so I bought a pioneer, buzzed. Kenwood started working again so I put it back in and no more buzzing. Bought a Alpine on sale and Buzzing is back.
I'm using some Tsunami RCA cables for the speakers, then some radio shack cables for the sub, I'm going to go check later today and see if there is a buzz through the sub since it comes through the door speakers.
Radio is grounded to factory ground wire from car harness.
Also anyone with an Alpine-117 notice a slight whine noise from the deck when it's on? :shrug:
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
It could be coming from anywhere, best way to figure it out is unhook stuff (not while the power is on) and see where the sound stops. Where it stops is where you have a problem.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
you should always add a headunit ground no matter what and glw finding the problem bro.
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
Most of the time its a grounding issue. Pioneers are known for it but it is a fairly simple remedy. Solder a piece of wire onto the ground of the rca cable(the circular part) then take the other end and put a ring terminal on it. Attach that with the proper size bolt into that small threaded hole on the back of the HU's heat sink. This might help, or check to see if you rca are crossing you power wire. You don't want them to if they are pull them away from each other, and if they have to make sure its at a 90 degree angle.
Best of Luck and Cheers!
There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
mine use to with a/c then all time then it stoped..now only when it rains :shrug:
strange cars..
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
  • Who's Online   0 Members, 0 Anonymous, 1750 Guests (See full list)
