2 15s, 3 12s, 4 10s, 6 8s for s trunk car
armykyle1
so I did some real measurements ( i guessed before sorry) I have 10.9 cubes of useable space w/o going in the the spare tire well and behind the strut mounts. so we'll just say 10 cubes.
the actual opening into the cabin is 38x17 but I can trim some of the sheet metal out to 38x19
i was doing some displacement math with the titanium 15 vs the 3 D6 12s and the rli-10/8s and the 15 has more actual displacement than any of the other setup, due to the high xmax. 1.75" and the SD is 800
so would a single 15 still be best or?
maybe 2?
do the 8's
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
here are the 8s i have
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-833
and yeah it does look sexy
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
maybe 2?
will a 10 cube box fit through the openings to get in the trunk? or are you going to build it inside the trunk?
I also wouldnt cut anything out, you might not compete now, but if/once you start youll be at a disadvantage.
and since you are dead set on filling the trunk completely, you have room on the face to do forward firing 15s, but unless you have around 8 cubes before displacement i wouldnt do it.
So if you can get a depth of around 27~28" then the 2 15s are do-able,
Because of lessened rigidity?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
No, because of not being able to compete in the trunk class.
is that just two sealed boxes or some kind of 4th order?
I like the neo motor, save a little weight and space. How do those sound?
maybe 2?
I would have to build in the trunk. I've never done this though. I'm guessing I'd have to use L brackets to secure it internally? lots of resin?
even if the seats still fold up?
I'll get a better pic later but where the top starts to curve I can go strait up and level with deck w/o hitting the cross bracing
am i correct by multiplying sd by xmax*2 to get total displacement of the cone?
