I know you guys are gettin tired of my noob questions but here what I have come up with for the SoloX18. Please double check or give me some suggestions.
Heres the box.
Heres my calculations on BassBoxPro.
-Ross
Project Layla
Truck: 99' F-150
Gathering things for my next build.
SoloX18 build:
http://www.stevemead..._1#entry1576460
RE T-line build:
http://www.stevemead...-between-build/
Not enough port area.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
Confused.. It says its tuned to 33.8? So how is there not enough port area?
You don't have enough in^2 port per cube. Need 14-16 or so. You may be tuned to that, but the port is too small.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
Can you please explain this a little more please :noob:
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
Open Torres calculator, enter your dimensions, and your port. You'll see it's like 8 in^2 per cube. You're tuning would be correct, but due to the port being too small you'd have issues with port noise and some other things. You need to make your port bigger so it's around 14-16 in^2 per cube. I use Torres for the basic design, then plug it in BassBoxPro for the plotting and fine tuning. Also don't forget to put in all displacements and figure for bracing before you start figuring port or it will change port area and tuning. Also I'd double baffle atleast with that sub.
-Zach-
2010 Toyota Tundra
7" BDS on 37's
sigh... people telling other people what they NEED when they have no clue what they're talking about them selves... op, gimmie the t/s specs of the sub and i'll tell you if thats enough port area.
im sure the port is too small, but you dont need 12-18 in^2, that all depends on how much xmax the sub has, how big the box is, and the t/s specs.
the last box i built had 5 in^2 of port per square foot and i didnt have a single noise issue.
Getting bass into the cabin of a W124 mercedes is impossible.
Current setup:
Temp 1999 panasonic HU
rockford 300.2 for fronts
rockford 200.2 for rears
rockford 400.1 for sub
Leaning towards a 8" in an exponential horn
DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
