2 channels on mono amp
I'm probably gonna get blasted for asking this. The 2 channels on mono amps are wired in parallel internally, right? So if I have two d1 subs, one on each channel wired series, the two 2-ohm impedences will equal a 1-ohm load at the amp.
Is my diagram correct?
SMD Super Seller
My Feedback Thread
Not to thread jack but how would I wire 2 dual 4ohm subs to an amp like this with a final Impedance of 1 ohm
Parallel cuts impedence in half. Series doubles it.
So each D4 = 2ohm load. Then each sub in parallel together = 1ohm load.
Parallel = wire sub positive to sub positive and negative to negative with jump wires, then tie both subs positives and negatives together in parallel and plug into one of the speaker terminals. If you wanted to, you could do each sub separately to each 'channel' since they are in parallel internally. Heres a diagram from 12volt:
  • Who's Online   2 Members, 0 Anonymous, 1298 Guests (See full list)
