Voltage is worse with xs batts?
i just got a 3400d from justinT i didnt get to check the resting voltage when i got it i just threw it in my tb.
when i started it up it charged to 13.6 and hasnt gotten any higher then 13.8 the last 2 days... stock duralast batt would charge to 14.x peepwall.gif
once i shut my off my tb it drops to about 12.5 and then keeps dipping down to right around 12.
is it the batt, is it not big enough for my tb, or what? any help would be nice, thanks
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
You got a used xs batt?
Sounds like a weak battery.
Could try to use a smart charger and desulfate it.
yeah it was used.
i would, but i dont have one or the money to buy one..
Was the battery used? I got a D6500, which is a little bigger than the 3400, in my 04 Trailblazer, and cold I was charging around 13.8ish I think. I have a VCM, which works great BTW, and I'm charging at 14.5 cold... Sounds about right...The resting voltage is higher though...
yes it was used. i didnt think the charging voltage was too bad considering its ridiculously hot out. but the resting is what scares me. you got a pm coming your way too.
Prolly needed to be thrown on the charger before she got thrown in.
I'm gonna say this wouldhave abeen a good idea.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
stinger, i havent used a dmm
use a dmm the stingers are junk.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
ok, thanks!
i threw it on a charger last week and its been sitting anywhere from 12.5-12.9
thanks guys!
  • Who's Online   1 Member, 0 Anonymous, 875 Guests (See full list)
