Ok guys im buying a new woofer for my car and am looking at the Treo SSp, my cousin is a dealer for Treo out here in AZ so as you can imagine i get good pricing...The sub will fire upwards and the port backward.
Sub: 1 Treo SSp 15.22
Amp: Hifonics BRZ2100 (for now)
now i just have a couple questions:
1) How good are the Treo woofers, ive had no experience with Treo's so i would like some insight from you guys and most of the reading ive done is that it IS in fact a good Company/Woofer, however would like a few more opinions to sway my decision..
2) The box im going to be building is where im kinda confused. With me having no experience with the Treo's, should i go with what the Rec Enclosure is off of Treo's Spec Sheets? (3cf^3) i can fit 4 cubes in car max, im just not sure if i should stick with what they say or go a little bigger...say...3.5-3.8???
Also take a look at these and make sure IF you guys reccommend going with a bigger enclosure if these will work and what will work better...
Edited by The Orange Goober
what kind of car is this going in? what size treo woofers are you getting? what amp is powering them
normally you can go a little bigger than the recommended box size and get more efficiency. if you are putting less than rms to them then i would go with the 3.8 cube box design up there. if youre running rms then you can go a little bigger than specs. if your running over rms then make the box around specs or slightly smaller. also why are you tuning them so low?
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
Well what size is the sub?
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
im going with a single Treo SSp 15.22, i thought i had put that in there but i was wrong, ill edit it, however its going in the trunk of my 05 Neon Srt-4 i know it fits, ive had a 4 cube box with 2 12s in it already so thats not an issue..
The amp im using is a hifonics brz2100, for now until i can get an AQ1200 or something along those lines..
