i have a 2003 chevy suburban and it idles at 500 or less . is this normal and voltage is around low 13's high 12's but once i put the rpm at 1000 and up i charge at 14 to 14.5 my question is doi need a new alt or a new pulley, is this normal?
ive got a 97 burb, does the same thing with a XS power D3400 under the hood, and a 300 amp iraggi alt.
look into a XS VCM or mechman AVBM
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Stock idle is 600.
are you worried that this is a mechanical issue or system related? and if stock idle is 600rpm i would try to keep it there IMO, why do you want it higher? how is the truck running otherwise?
well its running great just that rpm idle is on 500 or less plus higher rpm = higher voltage
They have a set screw on them that is not really made to be an idle set - it is just a stop, but you can replace the screw with a longer one an use it as a manual idle set. That is what I did in my suburban.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
well i cant really help much in the system dept but mechanicaly maybe a little...i assume its not throwing any codes? did it just start this out of the blue or did you change something?
crazy my truck did same thing this morning.03 silverado .called my brother this morning said clean the throttle body plates.may have build up.and if your careful clean the mass airflow sensor.havnt tried mine yet will after work.
  • Who's Online   0 Members, 0 Anonymous, 1531 Guests (See full list)
