im working on designing a fourth order for 4 10's so i can give you a little help. theyres normally a 2:1-3:1 ported to sealed ratio. the sealed side for 2 15's would probably be around 2-3.5 cubes but im not exactly sure about that. the ported side gets tuned to 45-55 hz.
also, the bigger you make the ported side the more peaky your box will be.
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
the reason they can be tuned so high and play so low is because the sealed side puts pressure on the subs so they dont bottom out at low frequencies. when you play the same notes in a ported box tuned to 3x Hz itll unload below tuning
Build Thread
UBL
1948 Plymouth
  • Who's Online   0 Members, 0 Anonymous, 1758 Guests (See full list)
