New Amp No Sound?
Hey Guys, I got a problem here i just got my Soundstream TX1.1300 in today and hooked everything up and even wired down the subs and got 1ohm to the amp. Everything is hook up right as i see it ground,Power,and RCA's, when i turn on the car it powers on and the light says its on but no sound is coming out of my subs. I have 2 Diamond Audio D615D4 DVC and wired them like this and have the negative speaker wire from the very end and the positive wire to the other very end making it bridged. The old amp i had worked but when i switched amps and wired the ohm down nothing comes out.
Thanks if anyone can help.
MASTER SLAVE SWITCH ON SIDE. I HAD THE SAME PROBLEM WHEN I GOT MY TARANTULA 1.5K A WHILE AGO. SWITCH IT TO MASTER!!! DONE!.
I'm a little new at this but i don't see a Master slave switch.
try flipping the rcas into the opposite terminal. thats what happened to me lol. there should be a master/slave switch on the same side as your rcas
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
Just try the RCA thing didn't work. There is a Bass Boost, Level, LPF, and Subsonic.
  • Who's Online   0 Members, 0 Anonymous, 917 Guests (See full list)
