OK, let me see if were all on the same page here? Plus I need all the help I can get! The drivers are still on my order list so I need help figuring out if I need D1's or D2's?? The way I was wanting to wire them what all 4 together, and strap amps to each other, so only 2 speaker wires will be connected to amp, and since there strapped, 1 amp controls the other, so tuning wont be a hassle.....am I correct here? If all this sounds right, IM HITTING THE "BUY IT NOW" BUTTON ASAP
with 4 D1s you can get a .5 ohm load or a 2 ohm load
with 4 D2s you can get a 1 ohm load or a 4 ohm load,
and yes with strapped amps you only tune the master amp, and the slave follows
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
so do you want a 1ohm final strapped load or .5ohm?
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
if i read you you want to strap them @ 1 ohm, so easch amp is @ .5 ohm before rise?
if so get D2
amps are ORDERED!!!!! I got them through DB-R so I dont think I have anything to worry about!! DB-R does great work... I guess Ill order 4 D2's???? Well, hold on, im confusing myself I think? Do I want a 1ohm load with all 4 connected, or a 1/2ohm load? Damn it, been out of loop a little longer then I thought!! Help. I am however pretty set on running each amp @ 1/2 ohm so when strapped together, it will be a 1ohm load...
I love my staffie :good:
So anti FACEBOOK it isn't even funny
wait. doesnt matter if they come with a warrenty. .5 each amp will void it lol :pardon: but glad you decided to go with sundown. ftw
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
I would go with the Sundowns just because of the warranty and also multiple amps will help control box rise more then a single amp setup
x2 sundown
Sundown is good but warranty will not serve them anything.
Warranty=No warranty you decide?
the amps are wired in series when u strap
so u want 1ohm load final, each amp seeing 1/2ohm
so get 4 d2s. its a good thing u waited since u will now get the newer style aqs with more excursion/cooling
Edited by Decaf
