ok so im building a new box for my 2 12" t200 subs and was wondering if this looks like an ok box design, the two aero ports will be in the center with subs on each side, and let me know if i need to do anything different with the ports if they are aero ports. thanks
Looks good but make sure you have a way to brace the box a little and you should be good
2011 Honda CR-Z Mugen
12" Kicker SoloX Subwoofer
Rockford Fosgate t20001bd
Pioneer AVIC-X930BT Head Unit
Build Log
is that enough port area ?? the only other configuration i came up with for more port area was 5x 2" aeros giving 15sq/inch port and you think i would need bracing for 2 12" t200s ?? using birch if that helps ?
Posted (edited)
I think two 3" aeros is going to be good. As for bracing, it won't need much. You may be fine. You might consider adding like a couple dowels between the aero ports and the subs on each side because the top and bottom pieces are a little big to not be braced at all. Other than that everything looks perfect
Oh my mistake, you may not have enough port. You may need to go with the 5 2" aero ports or even a center slot port
Edited by DRauck
Build Log
In fact, you may want to go with three 3" aeros
Build Log
Posted (edited)
3 3" aeros is 21.20 in² seems high and i cant get the tuning down to what i want without going external ports :-/ and you think i will need bracing going up and down connecting the top and bottom or baffle and back ??
i was thinking 5 2" aeros giving me 15in/sq ports
Edited by michigancapri92
I cannot see how the design because I'm on mobile. How much port area do you have?
He's got 3 cubes with two 3" aeros (14sq.in) at 32hz. Port area needs to be at least 25sq in. or so
Build Log
Posted (edited)
i have 14.13 in/sq port 3.02ft/sq volume after woofer/port displacement sunded to 32.29hz box is 14"tall 14.75 inch deep 37.25 wide with double baffle
ive been told 14-17 in/sq was decent port area
Whoever said that meant 14-17sq in PER cube, but that is for a slot port.
You can get away with like 8-11sq in PER cube with aero ports. You have 3 cubes, so you need 24-33sq in of port. Understand?
Build Log
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
