any wire would work really, i use speaker wire. any 14-18 is just fine
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
I would use 16 or 18 awg wire for it. You arent drawing much current with it so there is no need to have 0 gauge going to your volt meter. Hell if you wanted to, you could use some remote hookup wire for your positive and negative wires but one thing with this is MAKE SURE YOU KNOW WHICH ONE IS POSITIVE AND NEGATIVE. Dont want to take the risk of reversing the polarity on it.
If you wanted to do it a cheap way just head to advance automotive or any other car store and get some hookup wire. Its like $7-8 for a 40 foot roll. Heres a link to what im talking about.. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Primary-Wire-18-Ga--40%22-Black-Card-Autocraft_5013747-P_N4022B_A%7CGRP2020A_____
They put it near the fuses and i used that when i had to make an accessory turn on for my radio since my envoy doesnt have an accessory wire to turn the radio on and off with the ignition.
ok thanks, ill just put tape at the ends so i know the difference. And when i wire it, do i just put the 18 awg and the 0awg into the power terminals on the amp. for both neg and pos?
Yes you can do it like that but it may not grab tightly and allow the wire for your volt meter to come loose and short out somewhere. If you can, see if you can put the wire for your volt meter on the ring terminal of your amps power wire.
Or you can give it a try by putting the 18 awg wire in the amps terminal FIRST, and then put the 1/0 wire on top of that and screw down the terminal as far as you can get it to go. To verify a good connection that wont break loose, try to tug on the 18 awg wire to see if it comes out. If it does then it wasnt getting enough pressure from the terminal screw.
Another thing you can do is get yourself some shrink wrap and get it big enough to fit over your 0 gauge wire and put your 0 and 18 gauge wire in that, connect it to the amp, then shrink wrap it so the wire cant come loose easy.
This isnt really necessary but i always take wiring into a safe way to prevent a short or fire.
that is 40 inches not 40 foot!!
WARNING: I speak 4 languages, profanity, English, sarcasm & real shit
2003 ford explorer
2 RF T1 D4 15s in a 6.8 cubic ft box
1 T1500.1bdcp
250amp ALT by Mike Singer
2 runs of 0 gauge
3 yellow tops
My bad, you know what i mean. lol.
no problem man. i just figured i would point that out so everybody knows. :drinks:
2003 ford explorer
1 T1500.1bdcp
2 runs of 0 gauge
3 yellow tops
  • Who's Online   0 Members, 0 Anonymous, 1187 Guests (See full list)
