jrot Posted July 28, 2011 Report Posted July 28, 2011 i was playing around with my kenwood head unit today that has quite a bit of x-over and eq options, well i don't have much experience with this and so i just play with it till i like how it sounds but would like to understand more about how it works and what it does and what it is. for example on my front speakers i have the option to set them to through 20, 30, 40hrz ect ect, then i can set the slope to 6, 12, 24, 48db (i think) i can do this front rear and sub all separate of the EQ settings. so what does this do and how does the x-over effect the EQ ect? i hope this isn't a super noob question but i was just curious how it all works in simplest terms possible.
kickass audio Posted July 28, 2011 Report Posted July 28, 2011 The slope works kinda like a cliff to make it easy. Lets say you are at the end of a hill and it is set to 80Hz. If you set it to a 2db crossover slope, it will be a very small and extended (further out) drop. Now if you set it at 80Hz but used the 48db slope, the end of the hill will drop off instantly and continue to be straight down the further out you go. Now in real terms.. If you set your headunit to 80Hz at a 2db slope, that means you are only lowering frequencies above (highpass) or lower (lowpass) than your frequency setting a very minimal amount. This isnt really a good thing because you are basically sending a tone through the speaker you do NOT want. Like for example if it was a tweeter and you set it at 3000Hz (3KHz) at a 2db slope and at highpass, a very good chunk of frequencies below that 3KHz setting will STILL play. This is very bad as you will blow that tweeter faster than you can think about it. Now if you did the same settings but at a 48db slope, as soon as music that is lower than 3KHz plays, it will be almost completely killed out and not get to the tweeter. I have my settings on my 3sixty.2 set at a 24db slope, i think 48 is quite overkill but i would do it for my tweeters if i could. And just so you are aware, just because you set the headunits crossover at a certain frequency and slope DOESNT mean that you will no longer get those frequencies. Absolutely NO crossover, whether its passive or active will EVER kill ALL the frequencies you cut off. There will always be a slight trace of it that bleeds through the speakers. Now how much of it that bleeds through is dependent on your slope setting. Another good way to look at it is to think of the slope like a garden hose. If you set the hose wide open and the water is flowing out, there is no restriction on the flow of water. Now lets say you give it 2db of a crossover point, it will slightly restrict the flow of water, the higher db you apply to the hose, the less flow of water you will get out of that hose but you cannot completely stop the water from coming out. I know its a long post but its just what i do when im explaining stuff, if you have any questions feel free to ask, ill be happy to help ya out. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
jrot Posted July 28, 2011 Author Report Posted July 28, 2011 thank you so much, this is exactly what i needed. ill probably read over it a couple times so it sinks in real well. and i don't mind the long post, thanks for taking the time.
Superjay Posted July 28, 2011 Report Posted July 28, 2011 actually...a brickwall will cut all frequencies off outside the given parameters. that's why it's called a brickwall Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
kickass audio Posted July 28, 2011 Report Posted July 28, 2011 ^^Hahaha. i still dont have issues with my 24db slope for my mids and highs. Idk about for my SMD since its not installed for probably another week (i work too damn much). I am overpowering the mids and highs by almost another 100 watts from the rating Rockford Fosgate gives them and they sound perfect and dont get hot or anything. As long as you set everything up right it wont cause any problem. I have bleed through on my highs because i can slightly hear vocals on the tweeters but its faint when you do hear it so it doesnt bother me. I have my 3sixty.2 setup like this: Front (mids) stage: Bandpass at 80Hz and 3KHz with a 24db slope Rear (tweeter) stage: Highpass at 3KHz (3000Hz) with a 24db slope Subwoofer stage: Bandpass at 31Hz and 80Hz with a 24db slope and infrasonic slope. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
RAM_Designs Posted July 29, 2011 Report Posted July 29, 2011 If you do a simple Google search you will find everything you could possibly need. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
jrot Posted July 29, 2011 Author Report Posted July 29, 2011 If you do a simple Google search you will find everything you could possibly need. thats what i started out doing but I needed it terms that even forrest gump could understand. "I'm not a smart man jenny"
