jmilch Posted July 28, 2011 Report Posted July 28, 2011 Finishing a box for a JBL MKii Specs call a 4" x 13.31" round port, which according to Torres calc is 4.3"^2 of port area tunes to 30hz. So.... can I get away with a single round port like the specs say? I read somewhere round ports needed less port area... Can anyone chime in? Quote Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
Autruche Posted July 28, 2011 Report Posted July 28, 2011 (edited) That's actually about 12.6 square inches of port area. Definitely not enough. I had a couple of JBL subs before, and built a box to manufacturer's specs and was less than satisfied. I went with a slot port giving it 18 per cube and it was way better. What size sub though? and how much power? Edited July 28, 2011 by Autruche Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
jmilch Posted July 28, 2011 Author Report Posted July 28, 2011 That's actually about 12.6 square inches of port area. Definitely not enough. I had a couple of JBL subs before, and built a box to manufacturer's specs and was less than satisfied. I went with a slot port giving it 18 per cube and it was way better. What size sub though? and how much power? Its a 12" MKii, will be powered @ 3 ohms from my AQ2200d, so seeing ~700-900 RMS, which is perfect for this sub. So I am trying to get a port figured out for it. I thought the single 4" round port was too small. Quote Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
Autruche Posted July 28, 2011 Report Posted July 28, 2011 A single six inch (inside diameter) round port should work for a round port, otherwise I'd try about 32-40 square inches of slot. Probably shooting for right at 2 cubes net. Just an off the top of my head estimate anyway. Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
RAM_Designs Posted July 28, 2011 Report Posted July 28, 2011 It's normally best to veer off from the standard enclosure specs that most companies give you. Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
jmilch Posted July 28, 2011 Author Report Posted July 28, 2011 It's normally best to veer off from the standard enclosure specs that most companies give you. Thank you RAM, I was wondering. Still didnt solve my port issue, but it did let me know I Am moving in the right direction. Thanks again Quote Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
jmilch Posted July 28, 2011 Author Report Posted July 28, 2011 A single six inch (inside diameter) round port should work for a round port, otherwise I'd try about 32-40 square inches of slot. Probably shooting for right at 2 cubes net. Just an off the top of my head estimate anyway. I looked up the price of aeroport and pvc 6", both are our of the question. So I am back to trying to figure out a slot port for the design. The outer dimensions are 17x23x16, and its .75" wood. Quote Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
Supercharged DCs Posted July 28, 2011 Report Posted July 28, 2011 (edited) If ports firing forward or rearward, Slot port with 3common walls, 15.5" H by 2-2.5" W with various depth to get the tuning you'd like. If ports firing upward, 14.5H x 2.75W tuned to your liking. Should work well. Edited July 28, 2011 by Supercharged DCs Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
jmilch Posted July 28, 2011 Author Report Posted July 28, 2011 Slot port with 3common walls, 15.5" H by 2-2.5" W with various depth to get the tuning you'd like. Thanks man. This design has the port in the center of the box, so its only one common wall. I am punching those in. Thanks again man, I do appreciate the help. Quote Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
Supercharged DCs Posted July 28, 2011 Report Posted July 28, 2011 If it's going to be 1 common wall, my numbers won't work out. Will it be from top to bottom in the center? Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
