Does anyone know how I can find out the length and diameter of my cars rear springs withought having to take them out? I have a 2007 honda accord 4door, and I need some taller rear springs cause of all the weight in the back and my 22s, I already have spacers in them but I lifted it as far as they can go so I wanna try to find the height and diameter of my stock ones so I can get some that are about 2.5" taller. I tried googling it and I called honda and they just said to look it up on the internet cause they didn't have that info. So can someone please help? Thanks!
I looked at my manual yesterday but I didn't find it but then again I was at work on lunch break in a hurry so maybe I didn't look good enough. Imma check it again and see if its in there. Thanks!
Pull it out, i took mine out in 10 min, loosen shocks drop axel springs will fall out.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Thanks, I guess that's what I'm gonna have to do. It just seems harder since I've never done it before but sounds like its pretty easy then. So I won't need a spring compressor?
look at them...close one eye and hold your thumb up next to a ruler...done.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
No spring compressor needed
put car up on jsck stands ( on frame not rear axel)
Put jack under rear axel and lift axel up a bit so its not just "hanging"there
Loosen shock bolts
Lower jack and your springs will come out
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Call a dealer see if have stock spring in stock...
