I will be running a 9515 DD on an AQ 2200.. big 3 is done........... i work at a shop and i can get optima for about 100 cheaper than normal. So the most xpensive optima i was looking at was 1100 CCA....... would this battery work for my system in the back without major voltage drops?? i just really wanna no cuz if this batetry will work my system will be hooked up by tomorow or wendsday instead of 3 weeks from now. Thanks YOU!
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
=) yellow lol.. i can get any of them but i heard yellow is best for audio am i correct? lol
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
i would go ahead and throw one of those yellow tops in for now, and if you have real bad voltage drop, get another yellow top and throw in there. if you can get em for $100-$150. i would buy those all day.. but i am a cheap ass though. :drinks:
WARNING: I speak 4 languages, profanity, English, sarcasm & real shit
2003 ford explorer
2 RF T1 D4 15s in a 6.8 cubic ft box
1 T1500.1bdcp
250amp ALT by Mike Singer
2 runs of 0 gauge
3 yellow tops
haha ok ...... cuz then i can enter SOTM!!! YAYAYA HAH I HOPE I WIN =P.. to bad prob not my first build, but oh well its actualy the first ive ever even messed with a system so im prouyd of myself lol!
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
haha and yes i can get for 190.. but the best one is 240.. our retail for the best one is like 380 lol!
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
From Optimas site.....
"RedTop: Use this for normal engine starting where an alternator immediately monitors the state of charge and provides energy to the battery whenever it is needed. This would describe most stock vehicles.
Automotive and RV under-hood starting
Heavy equipment where starting is the primary function
Diesel powered vehicles with no aftermarket electronics
YellowTop: Use this when electrical loads are higher than average, or when the discharge cycle is more than typical engine starting, such as vehicles without alternators. This also includes vehicles with significant electrical loads that may exceed the average alternator output (for example aftermarket audio system, GPS, chargers, winch, snowplow, inverters, drag cars). This can also include vehicles that have a lot of electronics from the factory, such as a minivan with power sliding doors and a DVD player, especially if the DVD player is used when the engine isn’t running.
Racing vehicles without a charging system (alternator or generator)
Dedicated drag racing vehicles
Diesel powered vehicles with aftermarket electronics
Car audio/video applications exceeding 250 watts over the OE system
Vehicles or heavy equipment with inverters, hydraulics, winches or other accessories
Electric vehicles
BlueTop: The BlueTop starting battery (dark gray case) is to be used when a dedicated starting battery is required and it should never be used for cycling duty. The dual purpose BlueTop (light gray case) can be used for both starting and deep cycling; it is a true deep cycle battery with extremely high cranking power.
Trolling motors, marine applications with heavy electrical accessories and RVs should use a dual purpose BlueTop (which is both a starting and deep cycle battery)
Use a BlueTop starting battery for marine applications and RVs when the battery’s only function is engine starting
Note: The difference between BlueTop and YellowTop deep cycle batteries is that BlueTop batteries have both automotive (SAE) posts and threaded posts, while YellowTops (other than D31T) only have SAE posts.
If you ever get confused on the color tops just remember: if it has a dark gray case then it is a starting battery; if it has a light gray case then it is a deep cycle (dual purpose) battery.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Electric vehicles
ok cool thanks.... so you think the 1100 cca deep cycle would be good ? if not could i atleast run it for a month or to before i get another one 0_o
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
  • Who's Online   0 Members, 0 Anonymous, 1422 Guests (See full list)
