Hey got some few questions about the sundown sa 10 subs. What kind of box should i get for the subs? Also if i get the dual 4ohm subs and the Hifonics BRZ1700.1D, that amp will work with the subs and i load them at 1 coil correct?
2 D4's will make 1 ohm
i got 2 10" D4's in 2.5 cf box tuned to 33hz and it sound awesome. (on hifonics brz1200d)
alright thanks man and do you think i need a bigger battry up front? or one in the back?
You might, I'd do the big 3 first tho and then see if you still have a lot of voltage drop first.
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
just to make sure thats.
1.get bigger wires
2. ho alternator
3. and?
1.get bigger wires
2. ho alternator
3. and?
your big three is just upgrading the wires.
1. alternator to battery
2. engine to chassis or battery
3. battery to chassis
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
1.get bigger wires
2. ho alternator
3. and?
The big three is actually adding or replacing three wires under the hood. Alt to battery positive. Batt neg to chassis and Batt neg to engine block which is where your alt grounds. You basically make the circuit more efficient. There's a lot of videos and tutorials for this but each car is different so not all grounds equally effective .
  • Who's Online   0 Members, 0 Anonymous, 1196 Guests (See full list)
