subs making a crackling noise
sup guys i've been driving my brother tahoe for the past couple of weeks and i just noticed the subs making a crackling sound i donno if somehow i managed to blow the subs or what they are 4 memphis prs with a 1k memphis pr amp all 4 of the subs are doing it
Did the box break a seal?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
it's sealed its a pos it feels like it's falling apart these subs and amp are also really old like 5-6 years maybe
i just need to know how to fix it before my brother finds out. he has a memphis 2 channel line driver that he got for an extra bass boost i doubt a i blew the subs but i may have. i have bad luck with memphis products
lol there are so many things that could have gone wrong in this situation. Is the gain on the amp cranked? Is bass boost on the amp turned up? You need to ditch the line driver all together, or at least tell your bro that. Do the subs still play? They may just be slowly dying because you're clipping them to hell.
2002 Camry XLE
35% tints all around
17'' Enkei FD-05 rims
Fi Q15 in 3.8cu ft box tuned to 32Hz
Pioneer DEH-P7200HD
AudioQue AQ1200d
4 Gauge Tsunami wiring/RCA's
mids/highs - OEM JBL system
AudioTechnix Deadner
Big 3 upgrade
My YouTube
turn it on and look at the box and see if the panels are pulling apart. how old the box? is it screwed together or just nails?
Jacob Sigmund
1 dc level 4 m1 18
1 audiopipe ap1500
2 runs of knu 1/0
Alex Bennington" <[email protected] ^^^ want one one email this guy he will hook you up!
If every sub is making the noise then it's going to be from the amp,rca patch cord's or h/u, possible something in the amp went and is giving you a heads up before causing more problems. Do you have something to else to hookup as far as extra sub or an amp to see if that may be the problem, diagnosing does require having some good known working equipment so when you hook something up you can then begin to eliminate each piece as you move down the line checking.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
the box is made out of some cheep wood it's carpeted and i don't feel like taking the carpet off but at some places it's slowing turning into dust and can be be rubbed off. the subs still play good. now that someone mentioned it i remember my RE used to do that and i needed new RCA cables so i may try that but he got his line driver because he couldn't stand the fact that my 1 15 beat his 4 12s lol
i didn't set the gain on the amp or line driver so i have no idea to be honest
actually with a sealed box the easier way would be to just push on one sub. the other sub in the same chamber should move outward. hold the sub in after you push and see how long the second sub stays out. that will give you a gauge on how sealed the box actually is.
putting a line driver in is the exact same thing as turning the gain up more. if the subs are blown its not your fault. your brother set it up for failure and it was only a matter of time before the subs failed.
yep. that would work too. if its like mine its the wood. i gotta put more screws in my box when it cools down a little later was listening to some decaf and it losened the screws on my sub and pulled stripped some screws out of the wood
Jacob Sigmund
1 dc level 4 m1 18
1 audiopipe ap1500
2 runs of knu 1/0
  • Who's Online   0 Members, 0 Anonymous, 787 Guests (See full list)
