Grandmas Toyota tarcel won't start, everytime she tries the alarm goes off. I guess it's something that Toyota thought would be useful, but it's being a PITA right now. I've looked it up, to fix the problem it says I need to find the alarm toggle. Where is it? Please reply ASAP, it's hot as balls out here :P
Does the car have a key fob? Or just a key? do you have more than one key to the car? Need a little more information. It may not have a toggle switch, it may require a process such as unlocking the car with the original key, then starting the ignition with it...etc..
Toyotas usually have a harness for the alarm between the ignition switch and it's harness just remove t harness and plug it's wiring directly into the ignition like it should be.
